Clutch slipping
Clutch slipping
Hello!
Lately I have got this problem that then clutch is slipping, read the Haynes and the pedal was to long. So i adjusted the cable and it got a lot better and the pedal is at is recommended 15cm height.
But still there is a slight clutch slip, noticed when accelerating in fifth gear up hills.. What is wrong?
I cant Se the clutch is so tired yet because the car has just covered 110`km (but it has had a welded diff for the last 10`km..)
My car is a late 360(86)
If it is clutch slip. then only options are that either tired clutch cover or is it pressure plate or it could be worn clutch plate.
1999 Volvo S80 T6 Quiet long distance cruiser.
1990 Volvo 360 GLi Waiting inspiration.
1989 Toyota Land Cruiser For days when wellies aren't enough inside the car.
1987 Volvo 360 GLi Being restored.
1986 Volvo 740 Turbo Sold, but not forgotten.
Re: Clutch slipping
try changing down to fourthNikdev wrote:Hello!
well mechanic changed the bolt for 2 days. untill my replacement bell housing came through the post!Nikdev wrote:A option that dont include changing componentskaos wrote:or your release fork is on the way out as mine was!![]()
Tell me more? How did u fix it?
basicaly one end of the release fork is connected tot he cluthc cable, the other end is stoped from pivoting too far by a bolt that goes tot he outside of the bell housing, on minet hat bolt had managed to wear the release fork so that the bolt could slip through. nought you can do really. espesially as no one makes them any more.
I would say it is the clutch on the way. Not sure what you can use to uprate but I do recomend not to use cheap replacment ones as they often do not last very long
