1.7 Water Pipe
WooDooUK
1.7 Water Pipe
Post by WooDooUK »
Hi All,
I am currently in need of the water pipe that goest from the water pump to the heater connecting pipe.
This one
I believe its metal pipe rather than rubber
Oh and any related connecters that go with it.
WooDooUK
Post by WooDooUK »
Still after one if anyone has one along with the fitting in the back of the 1.7 water pump with the little t-piece in it.
Bottom Rad hose would also be handy.
kaos
Post by kaos »
you killed yours?
WooDooUK
Post by WooDooUK »
Mine was a bit of a bodge Job, and today the bottom hose came off the back of the waterpump, so i thought i would renew my efforts to get it sorted :)
srtames
water pipe
Post by srtames »
you may be able to use silicone pipe and elbows to make up one. Type "silicone heater pipe " inyo Ebay for supplier
good luck, Steve
1989 340DL,1397
1979 CapriGL ,1593
Post by classicswede »
If I remember correctly one end is 19mm and the other 16mm. Should be easy to get from the scrappies.
WooDooUK
Re: 1.7 Water Pipe
Post by WooDooUK »
Unfortunatley all the scrappies round me are devoid of 340s and now the time has come for mee to try again!
Also after the T-Piece from the back of the water pump still
Re: 1.7 Water Pipe
480T's have a very similar setup mate, with the metal pipe, but the t piece has an extra leg. Might be the same with all 400 series? They seem to be in scrappies still
kaos
Re: 1.7 Water Pipe
Post by kaos »
ive got one but im not sure if im using it yet wil let you kow when i strip the engine down this weekend.
