what management would be upto the job and injectors wise would the std 940 fuel rail and injectors go stright on the side of the std 2.0 360 block
sorry for the newb questions
Cheque, postal order or cash is fine. In fairness, I was a member when Ali was building it so I followed it with interest.volvosneverdie wrote:I.O.FJ - ten squid.
That depends on your definition of trouble. Yup, it works. No, it won't happen in a weekend. Ali put a lot of time and a fair bit of custom fabrication in, stock B200 won't run silly boost but Ali saw 170/180 from it. If you are keen, be prepared to have to do a fair amount of learning if you've never done tuning before, even at the point that car is you can blow things up if you don't have a clue. Having said that, most people want to learn, and the knowledge is here...skipp123 wrote:so it works then without too much trouble.
