Directly started on the F3N. I found out its the 109hp version with fenix ECU.
Fitted the 1700 crossmember:
The old 1700 engine, sump already switched:
clutch parts:
The prise-bearing is fitted in the crank, I did'nt know. So I was stuck on not having a bearing. After Xmas I 'll buy a new bearing.
So what now? Electric stuffsss.. I'm colorblind, so a mate helped me out. Afterall the colours didn't match any book, or scheme. Demanteled the whole electrics.
Lambda
Knock knock sensor. take a look at the original heat exhanger
Exit old crappy electrics:
Wiring is ready for use. Engine is almost ready to fit the 340.
