16v Loom!
pistonpen paultje
16v Loom!
Post by pistonpen paultje »
Tonight I started rebuilding my clio 16 engineloom. But hit 3 problems...
What are those 3 things?
Hmm, dutch...See if I can get any in english...
Edit: http://www.priyantha.nl/rtc/upload/guide.zip
Hmm, this gives another loompicture...Found out what D is -> Waterpump timer relais...This has something to do with fuel heating??
Also found out what that thing is what goes to 310...Rev- counter signal...What the hell? Doesn't the ECU measure this?
But what the hell is T?!
kaos
Re: 16v Loom!
Post by kaos »
water pump timer relay, i would say is for the auxillery water pump that the engine normaly has, that allows water to continue being pumped arround the engine after you turn it off.
Re: 16v Loom!
Post by 340GLT »
Drop me a PM with what you are stuck on.
Ovlov 3.6L
Re: 16v Loom!
Post by Ovlov 3.6L »
Pistonpen Paulus, I think Kaos is right. Much Volvo 400-engines have also this elektrical waterpump which cools the engine after the ignition is turned off. My B18FT has it also.
What "T" is........I don't know...............maybe it is a resistance?
