Please introduce yourself here, your Volvo 300 hobby... NO technical support, parts requests or car advertisements here
The volvo starter motor i had on it last was brand new! it would work fine then scream non stop for a few days, you coudl take it out and put it back in and it would work fine again for a bit.
I'll try shimming as that might nock it back a bit, ive just purchased the 5/6 starter motor to try! i expect the same results to be honest!
I hate old fucking cars!
My volvo aint going no where with this problem!
My baby works! Its cost me all of 5p to fix, untill friday! when my spare decent bell housing goes off! 2mm washers on each bolt- between bellhousing face and starteer face. And its fired in to life so far: 6 times on the key before the golfs battery i was using ran out of charge so back to ordering adjustable top mounts. and welding random pieces of metal in to place!
Tomorrow will be the test, ive got the battery on charge( the one i pinched from our golf m2) and the starters still in place, so heres hoping tomorrow it just fires straight up on the key each time, and if it does i will be glad. Ive been smiling all evening because of it. a new lease of intrest as such now!
Ok. its fired up fine no problem over and over, problem now is starter stays engaged! so thats got to be something stupid, maybe time to try another shim.
kaos wrote:Ok. its fired up fine no problem over and over, problem now is starter stays engaged! so thats got to be something stupid, maybe time to try another shim.
Dude, im no expert.
but have you had a priest look at it?
its one of the starters that has worked fine before the car is still at a slant aswell, so im wondering if something inside the bell housing is loose maybe the flywheel its self.... although i'll take the shims out tomorrow and see what happens then I know its the starter because its spaced out i can see sparks coming out of the small gap! so its firing nicely! not staying running mind you! it needs throttle to keep it running right now it stalls the minute theres no throttle!
