1) When removing the P/S pump from the 1.8 16v block what belt (shorter -from the crank to the water pump) do you need to use/where do you get one?
2) What radiators are you guys using on the 1.8 16v engines? The 1.7 volvo radiator in the car has developed a nasty leak so I cant use that, I do have a mk1 clio 1.2 radiator that I was going to replace it with until I noticed that the coolant inlet and exit pipes are on the same side (where as the volvo rad enters one side and exits the other) -although this may not be such a problem on the conversion? I figure I'm going to have to do some custom bodgery on the plumbing anyway..
3) As i'm going to be using R1 carbs do I need to keep any of the old Renault loom? I couldnt find much information on the wiring side of things?
4) With regards to ignition, I take it the volvo coil is used? and then hooked up to the renault dizzy? Where is the pickup/firing signal taken from? (e.g. crank angle sensor, trigger wheel etc?)
5) If I will be using the volvo ign., will I need any of the volvo loom?
Thanks, any help is appreciated, I am taking photos so a progress thread will follow shortly! (just finished respray, wide arches on the way!
