Post
by jtbo » 09 May 2009 08:51 pm
Fitted oil seals today, then all pulleys and gears, put tensioner and spring on place and also timing belt.
I did cut one coil off from tensioner spring as it certainly was too stiff so now it still works as it should, it moves belt full range and there is no any problems, it is just lot easier to put together, no any cursing and battling with spring, also belt is properly tight, not insanely tight as i was before so now it does not make weird noises either.
Had to get timing of cam and aux shaft right also as I had already forgotten how they were, luckily I had photos so I thought tjat made it pretty close in first try, then turned motor by hand to notice that valve does hit piston (teaches to line up all timing marks before removing belt). Checked everything from beginning to match and all was good then, no clank when turning motor by hand and all timing marks lined up perfectly.
Installed battery, turned key and it did start instantly, now just need to put radiator, belts, radiator fan and all that in, oh yes and have to torque tighten all bolts to make sure nothing is loose and perhaps apply some loctite to crank bolt. Then it needs motor mounts, front strut top mounts, that beam under engine and some welding. don't know when it will be ready and who knows if it still leaks oil which can cause setbacks, but at the moment it looks like being on road for mid summer festival.
Volvo 343DL vario -81 -running-
Citroen ZX Dturbo -97 -daily-
