samueljon wrote:after having the car running and starting first time now, the starter motor dies i think (go to turn the car over and the it just clicks)
any suggestions? a good whack with a hammer didnt seem to do alot, then unbolted it and run power through it still nothing
That'd either be a sticky starter, or most likely a bad earth on the engine block. Did you try the thing I suggest by putting the braided strap from the neggy side of the battery to the front side of the block beneath the rocker cover? I had EXACTLY the same problem with mine. Started once then just clicked. Changed the earthing point and it starts every time now
Try that, failing it I'll grab a pick tomorrow where mine is mounted. Got interwebz now.
Otherwise, try putting the car in 5th gear, and rock it back and forth a good few times with nothing running. It should free up the starter in theory. Apparently the starters are very picky about earthing points though
Speedy88 wrote:
Leave choke on, idling obnoxiously until neighbours peer out windows at the noisy exhaust
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Hammer is always the best way to deal with any problem...
Jon the earth for the engine is on the inlet manifold and I've got it running round to meet the battery negative on the body. It has started every time before it just doesn't want to get finished!
Will do what you said and role it in 5th tomorrow will hopefully just be a little sticky where it hasn't run
Guh, that does suck. Fingers crossed lad! Let me know how you get on.
Rev engine to 7K
Win at life.
Where does the main earth from the battery go, it should go to the block. The earth on my loom should go to the back of the head. Your using the engine bay loom from the new car aren't you??
ye i have the main engine earth coming from the inlet manifold and earthing with the negative from the battery (take it thats right otherwise car didnt turn over)
then i have your loom earthing at the back of the engine
so what your saying is the negative from the battery should go on the engine?
Yeah thats right. The braided neg lead goes from the battery, bolts to the chassis at the bottom of the battery tray, and rest of the braided lead bolts to the block.
Rev engine to 7K
Win at life.
If there was a like button, I would "Like" that comment
Anyway Sam, Ive put a few pics on face book of the earthing lead. Tagged you in them, have a gander. (photobucket doesnt work at the mo)
Rev engine to 7K
Win at life.
