John's valvo *Back on the streets!*
Re: Clio 16v *I gone and blowed it up*
Post by filthyjohn »
Good job they're easy to fix eh mate? I'll be getting a rev limiter for mine, I didn't think it'd be necessary but these little valver lumps rev like rotaries, one stab of the throttle and you're at 10k.
stealthstylz
Post by stealthstylz »
What are you doing with the engine that blew John? I was gonna bid on that one in Barnsley but i'll let you have a go as you need it more than me. However I need a mockup engine and yours could be just the ticket.
Matt
Post by trabitom99 »
filthyjohn wrote:... but these little valver lumps rev like rotaries, one stab of the throttle and you're at 10k.
:D :D :D What an experience!
stealthstylz wrote:However I need a mockup engine and yours could be just the ticket.Matt
Sounds like a plan!
PM'd Matt. I got outbid on the Barnsley one, shame as it had kent cams apparently.
sven360
Post by sven360 »
filthyjohn wrote: one stab of the throttle and you're at 10k.
Hmmmmmmm..a BDA will do that all day.
A bog std Renault valver once for 3 seconds.
Little less lead in the right foot leaves FJ's wallet healthier.
ARP bolts and a bottom end balance for the new un?????????
Write it in your heart.
The code of the West.
Just a rev limiter will do the job. The problem is, you can be flooring it in 2nd, hit a bump and take some weight off one rear wheel, and it's over-revved before you can even lift your foot.
kaos
Post by kaos »
filthyjohn wrote:Good job they're easy to fix eh mate? I'll be getting a rev limiter for mine, I didn't think it'd be necessary but these little valver lumps rev like rotaries, one stab of the throttle and you're at 10k.
see the club in general..
its not so easy... :(
sven360
Post by sven360 »
filthyjohn wrote:Just a rev limiter will do the job. The problem is, you can be flooring it in 2nd, hit a bump and take some weight off one rear wheel, and it's over-revved before you can even lift your foot.
What mileage are these engines you're pelting in?????
They'll have been given death from day one that's for sure.So you pelt it in bolt your gobblers on and give it more death until it surprise,surprise dies.
Put your rev limiter on if ya want but the sensible money is on ripping it apart and making sure it's right.
Oh and if ya do nowt else put some ARP bolts in it-made many an XE rev like a mother for quite a lot longer than it really should've :wink:
It's quicker to bolt a new one in than change the rod bolts. As long as I keep it below 8, the next one will last a while and I can sort out a specced up lump while I'm killing a cheap one.
filthyjohn wrote:It's quicker to bolt a new one in than change the rod bolts. As long as I keep it below 8, the next one will last a while and I can sort out a specced up lump while I'm killing a cheap one.
Dude, youre already planning 2 engines ahead.
This is not a good sign. :lol:
You always need a plan B. I've bought an R19 lump in Bedfordshire, should be collecting it after work on Saturday, and back on the road by Sunday afternoon.
Good news dude. Congratz
stealthstylz
My old valver reliably revved to 8500rpm with a lightened and balanced bottom end and ARP stud kit. Sounded nice too.
Matt
I was taking mine to 7 purely because that's all the tacho goes up to. The carbs made it sound ace at those heights.
kaos
Post by kaos »
sven my enigne was rebuilt before it went in, jus the opump gave up the ghost, im at the stage where yess if i can go out and pcik a valver lump up tomorrow i would just to drop in whil i pull this one out, but ive got a 2ltr int he back of the van i coudl also drop in etc.
