12/07/16
well today was a disappointment in trying to remove the windscreen it decided to crack
So no pictures as i was in a mood that the glass broke.
14/07/16
Today was an early start, was ready to go at 8am, so not to make to much noise I welded in the new panel i made for the floor pan and inner (inner) sill.
IMAG0127 by Benjamin Charlton, on Flickr
IMAG0128 by Benjamin Charlton, on Flickr
IMAG0131 by Benjamin Charlton, on Flickr
IMAG0132 by Benjamin Charlton, on FlickrBy this time i was able to make noise, so cracked on with the other chassis leg
IMAG0129 by Benjamin Charlton, on Flickr
IMAG0130 by Benjamin Charlton, on FlickrSorry for the lack of photos, I'll be honest I was to engrossed in the welding
IMAG0133 by Benjamin Charlton, on Flickr
IMAG0134 by Benjamin Charlton, on Flickr15/07/16
So today as the weather was threatening to not be nice, I decided (when i say decided there really is a plan behind all this and which job to tackle
marked all the spot welds and cracked on
IMAG0135 by Benjamin Charlton, on Flickrremoved the very rusty corner inserts
IMAG0136 by Benjamin Charlton, on Flickr
IMAG0137 by Benjamin Charlton, on Flickr
IMAG0138 by Benjamin Charlton, on Flickr
IMAG0139 by Benjamin Charlton, on FlickrHave not decided if i am going to rebuild them or make new or use the ones that are on my car at the moment
Then layer number 2 came off
IMAG0140 by Benjamin Charlton, on Flickrand the remaining piece
IMAG0141 by Benjamin Charlton, on FlickrSo then i decided to look at the panel on the car, marked all the spot welds and then well i....ermm....got bored so removed the spot welds and then removed the top layer.
IMAG0142 by Benjamin Charlton, on Flickrthe inserts are better condition than the donor
IMAG0143 by Benjamin Charlton, on FlickrRemoved the 2nd layer
IMAG0146 by Benjamin Charlton, on Flickr
IMAG0147 by Benjamin Charlton, on FlickrAnd now we can see the extent of the rust (Ride_on going to have to pick your brains).
IMAG0144 by Benjamin Charlton, on Flickr
IMAG0145 by Benjamin Charlton, on Flickr
IMAG0150 by Benjamin Charlton, on FlickrSo as you can see, going to have to rebuild the corners, both 2nd layers are the samebut the donor top layer is better than mine but going to use/make new corner inserts.
If anyone has any suggests on how the corners that have rusted are layered up (pretty pics welcomed) that would be great please.
Thank you
Got 16 days off soon, so will hopefully tackle and complete the corners
Ben
