Page 2 of 2
Re: v5 question
Posted: 13 Jan 2011 01:47 am
by Speedy88
Just because chris and mag and me have broken props on valvers doesn't mean they can't take 1billion horsepowers
Hurry up chris and make an alley prototype.
Re: v5 question
Posted: 13 Jan 2011 01:53 am
by filthyjohn
And me. Bellhousings too, 2 died on me.
Re: v5 question
Posted: 13 Jan 2011 02:27 am
I've a feeling everyone else will be snapping bellhousings too if my theory is right
John, what state were your front/rear engine mounts in? I'm hazarding a guess at good ish up front, shagged rear? And what way was your inlet mani, standard or flipped?
Re: v5 question
Posted: 13 Jan 2011 10:24 am
by pyro
Speedy88 wrote:pyro wrote:still got the volvo, just wish it was a diseasal.
im still trying to get in touch with pete farrell about the diesel conversion he has for a 360.
Ben
Could do, but you'd get 55mpg and 120BHP from a f-type diesel from a kangoo with 340 running gear
im sorley tempted, ive just grown attached to my 360. If i was going to swap for 340 running gear id just get a 340.
f-type diesel? electronc injection or normal mech?
Ben
Re: v5 question
Posted: 13 Jan 2011 02:15 pm
by Speedy88
Electronic I would imagine, it's a newish car/van
Re: v5 question
Posted: 13 Jan 2011 05:17 pm
by filthyjohn
Chris_C wrote:I've a feeling everyone else will be snapping bellhousings too if my theory is right
All wobbly. The rear mounts are an awful design, they should be like the fronts, inclined at 45 degrees and preferably poly. From struggling to fit the prop I'd say the front of the engine is too low, spacing the mounts out or fitting longer ones may be a solution, but the best approach would be adaptor plates and 360 transmissions.
Oh and I had carbs, so custom manifold.
Re: v5 question
Posted: 13 Jan 2011 05:46 pm
But dont the 360 drivelines have that weak piece too? Also... how would you do the engine mounts in a better situation? The best part about that setup is the front only needs 2 mounts and aligns itself with the gearbox. We can't do that easily with a Renault engine
Re: v5 question
Posted: 15 Jan 2011 10:57 am
by filthyjohn
Yeah but the weak piece can take 200lbft. With my B200 I could quite happily do 6000rpm clutch dumps at the lights and give it hell all day. Engine mounts could be fabbed to put any engine in a 300, it's really quite easy with a bit of measuring. But if you were going to all the trouble of adaptor plates and custom engine mounts you might as well fit a vauxhall XE or honda K20.
A bit of a dead end really, the F series is still the best swap in terms of bang per buck, so a bit of effort to improve the engine mount situation would be a good idea, and improved ones would sell.
Re: v5 question
Posted: 16 Jan 2011 07:36 pm
Yeah, pretty much what I've got round to thinking mate. I've sussed out a new design, now I just have to remake the silly pressed tin uprights
And beef up the subframe before that fractures too
Re: v5 question
Posted: 18 Jan 2011 04:42 pm
by pyro
finally managed to get through to the jumped up welsh (no offence dai!) tossers at vosa.
cant fit me in untill the 28th, two weeks for paper work. and they wouldnt accept the card i tried to use. as it wasnt in my name.
im sure they make it as hard as possible.
its funny, i get pulled at a spot check and they will do this test for free, at the side of the road in the pissing rain. Give em a warm work shop and they want paying. c*nts.
Ben
