Drive failure - gearbox?
i'm not so sure - if it was just the torque tube then it shouldnt happen when being towed whilst in neutral..
Good luck mate, that site is pretty comprehensive and helpful for replacing the torque tube. It is a relatively common problem (more so than a dead 'box) - the white 360GLT that was on Ebay sounded like it had the same symptoms as your new car - which everyone agreed was highly likely to be a torque tube problem. I'm certain the new owner of that car is lurking around here, maybe he would be able to provide some useful advice
- RandomHero
- foggyjames
If you don't want to mess around, just replace the entire drivetrain
Lot of work though...and you may not find out what's up with it.
