Jet soon is now a 2.3 Turbo!
Re: Jet soon to be a fully working 2.3 Turbo!
Just managed to mod the original intercooler pipe work to a perfect fit.
- foggyjames
How are you getting on with obtaining oil pressure?
Should be able to pop down Tuesday or Friday...?
- foggyjames
Bump! After finding that "Itchy and Scratchy mechanics" (that would be Adam and Sam
I'm allowed to be rude about them - I spent too much of Tuesday night lying in a pool of oil! The shower ran black!) managed to mis-seat the seal on the block end of the transfer pipe (between pump and block), we re-seated it with a fresh seal, and now have lots of nice oil pressure...and there is open downpipe video lurking out there somewhere. It's running really nicely. To be fair to the guys, it's a piece of crap design, and a tricky job to install the pipe correctly...been there, done that...
Just need to reassemble the drivetrain, finish the wiring, and get an exhaust sorted out, and we're in business!
The only hurdle to correct operation remaining is the lack of space for the wastegate actuator...i.e. very little (if any) boost. The donor car was one of relatively few early 940s to be equipped with a Garrett T25 instead of the usual Mitsubishi TD04-13c, and it appears that this is not a good thing (tm) when it comes to fitment in a 360. I also think the engine mounts have done their usual saggy trick, which isn't helping. The temporary plan is to use the adapted front crossmember (with 240 mount) originally from Kev Strong's 360 Turbo, and figure out a long-term solution later. That will both locate one side of the engine correctly, and give us the clearance we need for the actuator.
"Itchy and Scratchy mechanics" What!!!
James if you are going to insult us at least call us by are real names
.......... Bodge it & Leg It!
Adam.
Adam.
Just been down the workshop and fitted Foggy's donation (crossmember/mount) and with a bit of beating it fit's a treat!
now we have the clearance needed for the actuator to fit, started her up and she fired spot on.
WE HAVE BOOST!!!
idles like a dream
Now to get back down there and have the fun of fitting the Prop/box/Diff as a 1man job
so by tomorrow we might have a fully working Turbo 360
sweeeeeet!!!
Adam.
WE HAVE BOOST!!!
idles like a dream
Adam.
- foggyjames
Nice work bud
i did wonder how you guys were getting on. have you moved from the unit yet?
heres a bit of a progress vid on mine
http://s1189.photobucket.com/albums/z43 ... a44e11.mp4
1994 3.5 v8 940
Dude! That's awesome. Get some pics/video up asap.
V8 one looks cool too. Can't place the engine... rover, reliant?
Speedy88 wrote:reliant?
They used Fords surely.
I say Rover.
I only say because I swear I've seen a flat-topped reliant engine just like that. Wasn't a v8 though I don't think.
Reliant used the Ford Essex V6 in the Scimitar, with (I think) the Cologne in the very last of the line.
That engine, however, is a Rover V8.
- foggyjames
I heard a rumour tonight that it...
a) Drives
and
b) Has a minor traction issue in second gear...
a) Drives
and
i cant wait to see it! is it still at the unit where we visited in the beemer? has the 940 been cubed now then too?
1994 3.5 v8 940
This is never useful....foggyjames wrote:I heard a rumour tonight that it...
a) Drives
and
