Renault 5 Turbo
Attack2001
Re: Renault 5 Turbo
Sorry for hijacking/diverting a little bit tom, But Anjo, how is your drivetrain putting up with the 200hp? I thought the prop set-up was struggling at around 130-150, have you broken any props/gearbox noses/bell housings etc? Thanks, Thomas...........
TurboTomSportive
Re: Renault 5 Turbo
Now worries mate, these are all questions I will need answers to myself
. Cheers
1989 (G) Volvo 340 1.4 4-speed 5 door. More Doors - More whores
- volvodspec
Re: Renault 5 Turbo
not too bad, i drive with solid engine mounts; this makes sure the engine stays in the same place when i give it the beans.
i'm also not so keen on clutchkick-drifting, i rather use the weight and engine power to slide; that also helps
but still... i broke a prop yesterday (mainly due to using launch-control
i've had the rear bearing fall out of the bellhousing so the shaft/prop were all over the place, i've snapped a few CV-axle's and that's about it..
so it's not bad; i've mounted a brandnew M47R gearbox with welded diff and proper oil and it hold's fine up to this moment
Re: Renault 5 Turbo
I'd be interested to know if solid mounts are actually any good. I take it the bellhousing output is at least lined up with the gearbox? In my mind it deffinatly wouldn't be any good with a williams but yours is really light, tight poly mounts wouldn't let it move much anyway.
Re: Renault 5 Turbo
Given how silly thin not only the engine mounts are, but also the subframe, solid mounts scare me.
I get huge amounts of vibrations since I poly mounted my engine (my rear view mirror vibrates when I give it some) and that has to be hugely worse with a solid mount fatiguing anything it can find?
- volvodspec
Re: Renault 5 Turbo
mine only vibrates at idle (the whole car does actually
) that's it! under throttle you don't notice a thing
it does require checking front and rear engine mounts every now and then as these tend to crack; i plan on strenghtening everything this winter/spring but the solid mounts will definatly stay
Re: Renault 5 Turbo
Missed this the first time...volvodspec wrote:biggest problem with this is that the starter teeth on the flywheel are on a different place compared to the 340's flywheel but a adaptorplate for the starter will solve that.
Whats different about them chap? I thought Valver and 5 flywheels were the same, that being the same as 1.7 340 ones (which is the same as a 1.4 340 one?)?
- volvodspec
Re: Renault 5 Turbo
the distance of the starter crown on the flywheel vs the crank, R5's crown is closer to the crank as the 340's so a 340 starter will stick engaged
don't know if they're the same as 1.7's though, i thought 1.7's was larger diameter
Re: Renault 5 Turbo
That could explain my starter issues...
Would also make this sexy lightened flywheel less useful
I'll have to pull it all apart to get a measure, cheers dude.
- volvodspec
Re: Renault 5 Turbo
easaly solvable though Chris!
just get an adaptorplate made for the starter with the correct thickness (the distance the starter crown is dis-located offcourse) this moves the starter away from the bellhousing but perfectly aligns it with the starter crown.
Re: Renault 5 Turbo
I reckon with the bolt pitch on a 1.7 starter there wouldn't be room mate, it can only be a mm or 2? One way to find out!
