Sunroof parts: guides 3269076 and 3269077
- volvodspec
Re: Sunroof parts: guides 3269076 and 3269077
pics? maybe i can create something new, should be easy if you get me the old pieces
- trabitom99
Ah, that would be perfect
I'll get some pics up this evening ...
- trabitom99
OK, here're the pics. I'm not sure if its the LHS or RHS, but you should be able to see what the problem is:
I guess it could be superglued, but the area is very thin - I don't know how long a quick fix would last.
trabitom99 wrote:You're right, they're all in one piece together with the cables. There are no Golde numbers on them.
sunroof_cable005_zpsd670f364.jpg by macplaxton, on Flickr
Can you tell the number that is on the piece of plastic in area circled red?
(I see some numbers on it there, but can't make them out)
- volvodspec
yeah i can make that from delrin or nylon, could even do one in steel or stainless steel depending on how critical the shape of this has to be, to me it looks like only the distance between mounting/cable has to be the same, the rest can vary so should be easy to reproduce; i try to avoid sunroofs
so never had the chance to look at it up close
http://www.bmw2002faq.com/component/opt ... 45fc3d890/
especially this linky
http://www.pelicanparts.com/euro/catalo ... .htm#item1
Got to be worth chasing up, considering they are putting 240 cabled in a 2002 it did show a motor though
EDIT: Given how eagle eyed MP is today... check the numbers against these:
http://www.squarebirds.org/vbulletin/sh ... 0a&t=14154
It's possibly a number upside-down, but then again it might just be me seeing things:Chris_C wrote:EDIT: Given how eagle eyed MP is today...
- trabitom99
@Anjo - sounds good! Will have to have a chat to you about that.
MP is right, there are numbers on the plastic blocks. Hard to make out, but I think it's
100 654 677
on both. And a symbol which looks like a Mercedes star.
100 654 677
- Hell Driver
What are the chances of me watching THAT exact Father Ted episode last nightmacplaxton wrote:It's possibly a number upside-down, but then again it might just be me seeing things:Chris_C wrote:EDIT: Given how eagle eyed MP is today...
Wait a minute, I can actually see the face of Chis C in those intereference patterns above the Bishops face....or is it just me seeing things
343 DL (W 80)
R.I.P. 77 343 DL vario
343 DL (W 80)
Quite high given the chances that Father Ted is on hard-rotation on More 4 and More 4+1.Hell Driver wrote:What are the chances of me watching THAT exact Father Ted episode last night![]()
Thank you Tom, glad I've had it confirmed now that it wasn't "an Elvis appearing in the toast" momenttrabitom99 wrote:Hard to make out, but I think it's 100 654 677 on both. And a symbol which looks like a Mercedes star.
