wheels sizes
Nimminz
Re: wheels sizes
Post by Nimminz »
not sure if re-calibrating the speedo is that simple - think eveyone using different sizes from standard just guesses.
mine just scrubbs the rear arches with 1" blocks and GLT springs on 195/45 15's on 8J. fronts are fine
Logan360
Re: wheels sizes
Post by Logan360 »
Yea i still haven't blocked mine yet.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
Re: wheels sizes
The bigger rolling radius will help correct the speedo. Almost every 300 series speedo reads about 10% fast
Nimminz
Re: wheels sizes
Post by Nimminz »
195/45 15s on an 8J makes em smaller than standard so mine will be out more than 10%, yeah?
Re: wheels sizes
I was on 195/50 and that was still 10% slow. When I changed to a 440 speedo that corrected the reading to almost spot on.
Logan360
Re: wheels sizes
Post by Logan360 »
So mine should be fine yea?
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: wheels sizes
You will be fine. Just check your readings with satnav so you know where you are with it. You will still probably be reading fast.
Logan360
Re: wheels sizes
Post by Logan360 »
Thanks heaps its one of those things that's been on my mind for a while.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Cliché Guevara
Re: wheels sizes
Post by Cliché Guevara »
VW Honda Vauxhall all are 4x100 stud pattern. search egay for 4x100 and google the meaning of the et if you are not sure. What its all about.
tautvydas
Re: wheels sizes
Post by tautvydas »
I have found nice set of R16 9j ET20 wheels with 215/40 tires. For upcoming season I am going to lower my 360 about 5cm front and back. Any ideas how these wheels and tires will fit on when it will be lowered? Should I expect fender scrubbing or something like that. Seller is living in another town so I would like to have some information before going and putting them on.
http://www.willtheyfit.com/index.php?wi ... 20#content
According to this rim should poke out about 6,5 cm and I think is a lot :)
Logan360
Re: wheels sizes
Post by Logan360 »
Yea you'll have issues with 16x9. If they don't stick out they'll hit the strut. Too wide me ghinks
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Re: wheels sizes
Probably need some spacers and a bit of trimming on the body for clearance
seannaayy
Re: wheels sizes
Post by seannaayy »
heres my 340 on 14's, lowered on 3" blocks and coilovers on front :)
tautvydas
Re: wheels sizes
Post by tautvydas »
seannaayy wrote:heres my 340 on 14's, lowered on 3" blocks and coilovers on front :)
What are the et and j of these wheels? :)
seannaayy
Re: wheels sizes
Post by seannaayy »
Only 5.5j 0r 6j, and can't quite remember offset either haha but it's very low!
