1.7 seizing up?
Re: 1.7 seizing up?
Duhhhhhh, yahhhhh. You're right - I was looking through the specs on eBay and found that some of them are 124 teeth (like the one I have fitted) and some are 125 teeth. Ok, nice one, top one, sorted. There's my Easter work cut out now, hoping that some numpty I trusted to work on this car (me) hasn't toastified the engine.... well, its not done too many miles like that ;-0
Re: 1.7 seizing up?
You should be ok - although the belt, pulleys and tensioners are different in each version as long as the cam and crank pulleys are matched (to give the 2:1 ratio) no damage should result.
Note - the tensioners should be those for the correct tooth belt. Ie:- you can't use "124 tooth" tensioner and idler with a "125" belt. But if you fitted a 124 on a 125 engine that would explain the difficulty in fitting and the noise.
Mac.
Mac.
Re: 1.7 seizing up?
The wrong belt does explain a lot
Re: 1.7 seizing up?
Yeah, I had a dose of severe numpty-itis over that.
Re: 1.7 seizing up?
Easily done - all part of the learning curve!
Just think of it as something you won't repeat.
Mac
Mac
Re: 1.7 seizing up?
Many cheers Mac, yes, its all part of life-long learning and I'll be in the Honda Jazz appreciation society soon (sold in the US as the Honda Fit). The new belt is a Dayco 94120, so lets give it a go.
Re: 1.7 seizing up?
Are you nearly 60?bogbasic wrote:I'll be in the Honda Jazz appreciation society soon.
I thought I posted on this thread the other day, but my moby must have been fooling me. Dayco belts are good belts. I think I wrote "Dayco good, belt short"
Re: 1.7 seizing up?
.... only 83% of the way....
Re: 1.7 seizing up?
Herein lies hope - my new cambelt fits lovely.
Re: 1.7 seizing up?
100 % sorted - well, just the quarter turn way, but it seems OK (might hire/beg/borrow the tool - time to nose on Dai's websitel). But, now to sort out everything else I should have been doing since last June....
Re: 1.7 seizing up?
Yes, its all fine - tested on a 50 miles run; no probs so awesomeness abounds.
Re: 1.7 seizing up?
Re: 1.7 seizing up?
Nice one BB!
Re: 1.7 seizing up?
Many thanks indeed for the very kind words but today has been a bit of a game-changer.... 340's I just love them....
Got back from another 50 miles run with the usual load and was negotiating a traffic-taming measure when I heard a noise that I've heard before..... can you guess..... here's a clue....
... this might take a few weeks to sort out but I'll be posting a couple of things to Dai in the next month or so, hopefully (Dai, I have the cups).
You couldn't make it up!!!But, now to sort out everything else I should have been doing since last June....
Re: 1.7 seizing up?
Funny enough I have just been fixing up some struts this week. Does not seem like long ago I did the 360 ones for you
