Page 2 of 2
Posted: 03 Apr 2006 08:10 am
by redline
jtbo wrote: it make awful klonk everytime I drive over sidewalk...
dont drive over sidewalk , problem solved lol
Posted: 03 Apr 2006 02:22 pm
by jtbo
redline wrote:jtbo wrote: it make awful klonk everytime I drive over sidewalk...
But it is these voices in my head, everytime I see old granny walking, they demand me to drive to sidewalk
No, my parking place is located so that I need to drive over sidewalk, it is not typical edge like this | but more like sloped like this / at the sidewalk, but it still makes noise. Also noticed when driving rough ice surface it makes sound and I can feel it in steering wheel too, there is loose bushings on those support rods too, but I have been too lazy to fix that...
Posted: 03 Apr 2006 02:50 pm
by redline
oh I see
I had this vision
out for a sunday afternoon drive in his slightly modified volvo 300
looking for signs like this one
lol
Posted: 04 Apr 2006 07:38 pm
by volvo300
jtbo wrote:Hey, those are knuts that I was not able to tighten properly as I had no good tool, also it took 3 hours to open one
They need to be tightened right to bottom, but my right side is not quite well tightened so it make awful klonk everytime I drive over sidewalk...
Hi Jani.
When I replaced the shocks, I got my fingers crushed between the wrench in the pic. It HURTS like hell when that happens, and it's now about 2½ months since I replaced them, but the marks on my fingernails are not gone yet.
The klonk sound was the same as my shock made... now it's gone and everything is nice
Take a look at my webpage
http://volvo300.dk/New-shocks.htm
There you can see the replacement of my suspension.
regards.
Peter
Posted: 10 Apr 2007 03:43 pm
by Raod
Hello to all.
I had a noise in my front suspension for 3 months and today I fix it with the info of this post, in ten minutes!!
To tighten the shock insert I only need lift the car, is easy to made with the wheel mounted.
Thanks for the info.
Rafa.
Posted: 21 Apr 2007 08:58 pm
by Fuse
I'm going to fit my red Konis in front soon, so I'll be changing other parts at the same time too. Top mountings are cracked so those are going to be replaced, but I think it's wise to replace bearings and cover plates at the same time too. In what condition are the upper spring seats generally, would it be wise to change those too at the same time?
I'm also going to change the springs, though I'm not yet sure if I'll go for stock GLT springs or some lowering springs.. Rear is currently lower than the front, so it wouldn't hurt to drop the front few centimeters.
Posted: 21 Apr 2007 09:32 pm
Best bet would be adjustable roller bearing strut tops.
BTW make sure you check the top spring cup for cracking around the bearing.
Re: Noise from front suspension
Posted: 28 Mar 2009 12:08 am
by habie12
kicking a old topic up,
here in holland there are no spring seat bearings anymore, where can i get them, and new spring seats, what would that cost??
Posted: 28 Mar 2009 01:11 pm
by nomead
Hmm, this worries me, 300 series parts that are not available in Holland?
Anyway. My bearings are probably going, or gone already because there's this crunching/grinding sound when I make tight turns on the parking lot. So I went to the local parts store (Motonet) again. They had three bearings in stock so I bought two, 8.75 eur/pc. SKF "Made in Argentina" and the SKF code is VKD 35012. It seems that this same SKF type is used in many other cars as well, so there should be no problem locating some, if you can accept parts that don't come in a blue box with Volvo written on it...
The SKF catalogue has the same code for Rover Maestro / Montego, Seat Ibiza (86-93), Seat Malaga (89-93). Also, some sales site quotes the part as matching for "AUDI 80/90/KOMBI/SEAT IBIZA/MALAGA /VW PASSAT/SANTANA/VOLVO 340-360" but no warranty on that information. For some reason Motonet has separate codes for the VW/Audi bearing and the Seat bearing. But they're cheap too, so I might just go and buy some to verify the match.
They also had the lower spring seats for 11,90 eur, the same stuff (NOR) as pointed out earlier here:
http://www.volvo300mania.com/forum-uk/v ... 269#p83269
Posted: 31 Mar 2009 09:28 am
habie12 wrote:kicking a old topic up,
That has been the case for about 2 years now I think. I think I can get the bearings but the seats would be an expensive job to get poduced.
Posted: 31 Mar 2009 08:06 pm
by nomead
So, I got the Seat Ibiza bearing - it had even the same SKF code as the Volvo bearing, I wonder why they keep two separate stock codes? Anyway, the Audi 80 / VW Passat bearing was slightly different. It came pre-installed to the strut top mount (VAG code 8A0 412 323D) but the bearing is exactly the same as on the Volvo 340 / Seat Ibiza. I can't recommend that though, unless you can get just the bearing, because it can be a bit difficult to remove from the top mount without breaking it.
Posted: 14 Sep 2009 03:37 pm
by mrsoundcraft
Im after some of these, how come you all found it so easy? Maybe Scottish dealerships have different rules.
I went to Seat,they said 823 412 249, was not a seat part number, Id need to go to Volkswagen. I phoned Volkswagen and they said it was a seat number and Id have to talk to Seat. I phoned seat back (who are also a Volvo service centre) and they said that It was a volkswagen, audi or Skoda part number, adding that the seat part numbers usually start with 1J0.
So within a week I'll have new shocks, springs, bushes, but a still no new bearings!
Posted: 14 Sep 2009 03:53 pm
by trabitom99
mrsoundcraft wrote:I went to Seat,they said 823 412 249, was not a seat part number, Id need to go to Volkswagen. I phoned Volkswagen and they said it was a seat number and Id have to talk to Seat. I phoned seat back (who are also a Volvo service centre) and they said that It was a volkswagen, audi or Skoda part number, adding that the seat part numbers usually start with 1J0.
My usual parts website quotes 823 412 249 as being an Audi, a Seat, a VW and a VAG part number. They're just being difficult
The last Seat it was fitted to, was a 1996 Marbella, maybe that's of help?
Otherwise try Boge part nr. 87-083-L from your local parts place. Only 4,65 EUR each according to
http://www.kfz-teile-preiswert.de
Posted: 14 Sep 2009 11:59 pm
by mrsoundcraft
Thanks, tomorrows the big day! Im going to put everyone to rights and get my own way
I'll try all the numbers I can and get the bearings. Once this is done I'll get the boss kit fiasco sorted out (3 months!)
then I'll be happy
Posted: 18 Sep 2009 11:43 pm
by magnumpi
I'm going to check my inserts tommorow then as my car still has a clonk but not all the time only on large bumps, i checked all the bolts are tight, but because i'm slack i just put up with it
