Page 2 of 8
Posted: 20 Aug 2006 02:21 pm
by Frits
That is nice to know! Doesn't it make a difference for the renault 1.4 engine? That prise-as is different from a 360 though?
Posted: 20 Aug 2006 05:00 pm
by jtbo
In my opinion that clutch won't fit to 1,4l engine as Renault and Volvo clutches are different.
I would look clutch from R5 Turbo (Or some other R5 rallye/gordini or what ever were/are made currently), then get made proper bores to propeller shaft if needed, maybe easiest route.
Posted: 20 Aug 2006 05:06 pm
by Fuse
But that Sacsh 210mm sintered clutch will fit, at least it is listed in the Sacsh catalog also for 1.4 and the part number is different. :P 228mm Golf disc then again might not fit as I think Volvo and Renault have different bores.
Posted: 20 Aug 2006 05:14 pm
by jtbo
Fuse wrote:But that Sacsh 210mm sintered clutch will fit, at least it is listed in the Sacsh catalog also for 1.4 and the part number is different. :P 228mm Golf disc then again might not fit as I think Volvo and Renault have different bores.
Certainly it will fit when it is listed there :D
So it will had also several pressure plate options?
Posted: 17 Sep 2006 10:07 pm
by Frits
Here you can see the difference between the volvo 1.4 clutch and the renault clutch. The renault splines are different, so you cant use it on the volvo prise-as.
Here, on the right you see the renault pressure plate, it doesn't fit on the volvo-flywheel. Another problem is that (I don't now how to say...) the volvo pressure plate is longer. So the renault pressure plate won't disengage when using the volvo belding house. (I think)
So, i think I'm gonna use:
Volvo flywheel
a new original pressure plate
and clutch I don't know yet (maybe SACHS sinterplate, but expensive)
Posted: 25 Oct 2006 11:37 pm
by Frits
The Sachs sinterplate is in:
Posted: 02 Nov 2006 03:48 pm
by Frits
I don't know what to do.. Maybe I try the original clutch, while I know it isn't strong enough.
I am a bit dissapointed because the Sachs don't exactly fit.
Posted: 14 Nov 2006 12:20 am
by Frits
Today I've been hard working on the engine:
The engine is ready to go in.
-mounted on:
the flywheel, clutch, housing.
-starter motor
-generator
-waterpump
Put off;
-All the shit of hoses etc.
-renault waterpump
-turboheader
-Inlet + carb
I hope next week the engine can go in the car, but I have still to do some things to tha car.
Posted: 26 Nov 2006 01:28 pm
by Frits
I did have mount the engine in the car, but it didn't fit. The lowest black part of the engine (carter?) hits the steeringhouse. So I need that part also from volvo. So I have to make the oil exit an the ventilation on the volvo one.
Also needed to change the oil control stick. I needed to change the oilpomp to, because the height was different.
Now the carter fits. I hope I have next week time to weld the oil exit and ventilation on it.
The fuel pressure regulator, its a GTT one.
Greets
Posted: 28 Nov 2006 01:00 am
by antiekeradio
carter = oil sump.
but that could be figured out from the pictures i guess...
Posted: 08 Dec 2006 04:11 pm
by Frits
Yes... Adjustable koni shockabsorbers for the back of my car!
I am happy :)
Hopefully I have this weekend time to modificate the oil sump.
Posted: 08 Dec 2006 09:09 pm
Well done mate - there is quite a bit of work going into this project.
Nice one :D
Posted: 08 Dec 2006 10:08 pm
Definitely, can't wait to see it complete - what a sleeper :D
Posted: 10 Dec 2006 08:39 pm
by Frits
I cleand up the engine a bit, with a airpistol, fuel. Works quite good.
Before:
After:
I really needed to take a picture of my real sleepy
I wanna drive it!!
Tomorrow I want to change the oilsump.
I still have a little problem with the oilpump, its higher, But I do think i can use it because of the next picture of the oilcheckstick.
Left is renault, right is volvo
Pictures from the oilchecksticks, left is volvo, right is renault.
Greets
Posted: 11 Dec 2006 03:38 pm
by Frits
Made the holes exactly the right size, than pushed the pipes in.
gave it the only color that I had at home. :P
Like real :lol:
