GLT leaf spring looks quite soft, 12,55kN/m, that can't be true and I'm not sure from my LBS-in to kN/m conversion if that is somewhat wrong then, but maybe someone can take a look and spot something...
Also I'm not too sure of width of leaf spring, length and thickness should be correct.
Edit: uploaded revised version of calculator (link above), got now conversion right and rear spring rate for 360 gls springs is approx 32000 N/m
If you add 2nd leaf, rate goes up to over 88000 N/m if that american formula is correct...
