Glad that iyou managed to sort it.
Just let me know as and when re the welding
B14 idles only on full throttle, difficult to start
hi there,
This cars problem was the rear box had collapsed. A removing the exhuaust at the downpipe and the engine ran well albeit noisely!!
THe running rich problem - I tried a replacement carb ( a spare from foggy) and unfortunately whilst the car ran better, it kept cutting out.
The car would start from cold ok but wouldnt restart. A roadside spark test showed the spark to be a little weak.
Working through the Renix diagnostic pages of the B14 engine manaul ( to be added to this site) showed that the coil primary resistance was a little too high. A replacement (spare) coil was marginally better so was fitted. I'll post the specs later once I have the book with me.
The idle solenoid was also tested. live 9V feed at the plug, a good earth from the carb but no click from the solenoid when connected.
A replacement solenoid is in the process of being repaired (the one I have has no blade connector)
The car will then be off to be tuned and welded!!
Shimon
Shimon
Enjoy your 300s
