The other angine swap option is a 2ltr lump out of a 400 series. Direct bolt in and does not look any different on the outside.
There is a fair bit to be gained with the basic a#exhaust and induction job. I can also get a tweaked cam for the 1.7
How To Get More Power
germ
i want a 2.0liter swap
i guess your talking 2.0liter 8v?
115hp stock with very nice torque and with tweaking my mates car got 140hp with simple mods exhaust intake and chip
^it was in a laguna so front wheel drive tat but imagin in a volvo 300
its mpi engine and he found that the stock exhaust and air box was a very big restrictoin
this is stock info on it:
82.70mm × 93.00mm
3.26 in × 3.66 in
Bore/Stroke ratio 0.89
Displacement 1998 cc
(121.925 cu in)
Unitary capacity 499.5 cc/cylinder
Compression ratio
Fuel system
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output
(DIN) 116.6 PS (115.0 bhp) (85.8 kW)
@5250 rpm
Max. torque
(DIN) 168.0 Nm (124 lbft) (17.1 kgm)
@3500 rpm
Maximum rpm
Coolant Water
Specific output 57.6 bhp/litre
0.94 bhp/cu in
Specific torque 84.08 Nm/litre
and 1.8mpi:
SOHC
8 valves total
2 valves per cylinder
Main bearings 5
Construction
Bore × stroke 82.70mm × 83.50mm
3.26 in × 3.29 in
Bore/Stroke ratio 0.99
Displacement 1794 cc
(109.477 cu in)
Unitary capacity 448.5 cc/cylinder
Compression ratio 9.80:1
Fuel system
Aspiration Normal
Compressor type N/A
Intercooler None
Max. output
(DIN) 111.5 PS (110.0 bhp) (82 kW)
@5500 rpm
Max. torque
(DIN) 160.0 Nm (118 lbft) (16.3 kgm)
@4250 rpm
Maximum rpm
Coolant Water
Specific output 61.3 bhp/litre
1 bhp/cu in
Specific torque 89.19 Nm/litre
i really want to see detailled pics of these engines to see what exacly needs doing for fitting
will
82.70mm × 93.00mm
3.26 in × 3.66 in
(121.925 cu in)
Compression ratio
Fuel system
Aspiration Normal
Compressor type N/A
Intercooler None
Max. output
@5250 rpm
Max. torque
@3500 rpm
Maximum rpm
Coolant Water
0.94 bhp/cu in
and 1.8mpi:
SOHC
8 valves total
Main bearings 5
Construction
3.26 in × 3.29 in
(109.477 cu in)
Fuel system
Aspiration Normal
Compressor type N/A
Intercooler None
Max. output
@5500 rpm
Max. torque
@4250 rpm
Maximum rpm
Coolant Water
1 bhp/cu in
will
Volvo 340
1988
1988-
stealthstylz
stealthstylz
Won't tell you what you can get 480 T's with knackered bodies for then
