Page 2 of 3
Posted: 03 Jul 2007 08:06 pm
by mattyboi
Driftmoto do steel props with flange fittings at each end instead of the rubber crap and sell them for about £250. I looked at getting some made but the cost was more because of the flanges.
I`ve killed four props now, two had dead splines and two had ripped rubber but i`m guessing it was clutch kicking that killed!
Posted: 16 Jul 2007 11:05 pm
by huskyracer
I've been making 240 lbs/ft @4k on a stock 1700 box for ages, think ive done about 6 thousand miles on it,
the stock props are pants though
Posted: 17 Jul 2007 01:07 am
Bloody hell Iain, you're alive! I've been trying to call you for ages - got a new phone?
Posted: 17 Jul 2007 07:31 pm
by huskyracer
Foggy, Hows it goin? no new phone no, still on the same number, but have had a few issues causing me basicly to stop using it. ring me at work or let me know and I will pm you the home phone, not that Im ever there atm!
Posted: 17 Jul 2007 07:42 pm
Iain what power are you making with your engine? BHP that is
Posted: 17 Jul 2007 08:16 pm
by pettaw
Alright Husky, long time no speak. I believe Iain was making approx 220 bhp last time I chatted to him.
Posted: 17 Jul 2007 08:18 pm
by germ
with steal prop? with flanges?
will
Posted: 17 Jul 2007 08:30 pm
by pettaw
yeah steel prop with 2 Universal joints.
Posted: 17 Jul 2007 10:00 pm
by Johnny A
huskyracer wrote:I've been making 240 lbs/ft @4k on a stock 1700 box for ages, think ive done about 6 thousand miles on it,
Superb, thats all I needed to know.
I am on the lookout for a 1700 complete drive system so fitting that with an uprated prop and clutch will make for a strong reliable setup!
John.
Posted: 18 Jul 2007 01:40 am
Sorry if this is teaching granny to suck eggs, but I'm sure you mentioned a redblock the other day. You're aware that the drivetrains are quite different for Renault vs Volvo engines, right?
1400 vs 1700 it's just the bellhousing (I presume...never looked up close at a 1700 BH) and the diff ratio which are different. The 1700 has some vibration damper widget too, but we don't care about that
If you're looking at the 1700 for low gearing, it uses the same ratio as a 360 GLT. It's the 1400 5 speed which has the low diff ratio.
Posted: 18 Jul 2007 09:52 am
1400 and 1700 definately are the same in so much as they use the same pattern output shaft from the clutch... don't care about any more than that so havn't looked
Posted: 18 Jul 2007 11:11 am
by Johnny A
foggyjames wrote:Sorry if this is teaching granny to suck eggs, but I'm sure you mentioned a redblock the other day. You're aware that the drivetrains are quite different for Renault vs Volvo engines, right?
Yes i'm aware of the Renault Vs Volvo drive differences.
Are you saying the 1.4 gearbox is the same as the 1.7 gearbox???
Well half the reason for the change is the fact that my 340 gearbox is a 4-speed!!
Which has the wider gearing? the 1.4 or 1.7?
Posted: 18 Jul 2007 11:41 am
Gearings are the same, and both 1.4's and 1.7's had 5 speeds. The only difference between them is the diff ratios
Posted: 18 Jul 2007 01:00 pm
Not all the 1.4 had 5 speed.
As far as I can tell the box is the same apart form the input end
Posted: 18 Jul 2007 01:32 pm
Thats what I ment, that you could get a 1.4 5spd! Badly worded by me
