Page 2 of 4
Posted: 19 Jul 2007 10:59 pm
It doesn't matter if the difference is 50mm or 0.1mm...if the stub of the hub isn't bearing any of the force exerted by the the wheel, you're putting a lot of extra strain on the studs. You'll probably be fine, actually, but if it's a case of spending £20 to have some piece of mind that your wheel won't come off when you're taking a tight corner at speed, it's a no-brainer.
Interesting comment about the mk2 rear drums. I've a niggling feeling that might be correct, actually.
Posted: 20 Jul 2007 09:20 am
by Johnny A
redline wrote:thats strange Johnny ,
I didnt use spacers with the vauxhall rims on the redline and it drove perfectly
It's partially a clearance issue (which yours obviously doesn't have) and also a handling issue (I know that fitting incorrect offset rims can cause tramlining and in FWD cars it can cause torque steer).
But if it doesn't do any of those that's cool!
Posted: 20 Jul 2007 12:36 pm
by Frits
I also have wheels, wich come from a golf.
The rear, without center thing:
Everything is ok, and believe me, i drive it like it's stolen twice
But like said, the front wil get more force, and for a few money more safety is not realy a doubt about. (for the center rings)
I haven't actualy
Posted: 20 Jul 2007 12:49 pm
by ajdubas
rear drums on my mk2 340 are flush
thought it was rather different, kinda scary looking without the middley bit.
Posted: 20 Jul 2007 01:23 pm
by Ronnie
I was going to go and take a photo myself but it was too wet - I've got one word for all you mk3 doubters out there:- SPIGOTS!
Posted: 20 Jul 2007 01:56 pm
I've never doubted a mk3
Still with Frits on this one though, I can't be the only one that thinks for £20 you've got the extra piece of mind when you go for a hard drive (which, tbh, most of us prolly do)?
Posted: 25 Jul 2007 11:29 pm
by huskyracer
Not all cars have a centre location for the wheel, although its not that common, actualy more common on light commecials for some reason.
The way I understand it the weight of the car is supported by the clamping load of the bolts holding the wheel to the hub, and the spigot is there partly as a handy place to fit a grease cap/seal to the hub, and to make it easy for the average punter to fit the wheel bolts (only have to turn the wheel to align holes and wheel usualy stays put while owner risks life and limb retrieving wheel bolts that have rolled into the outside lane of the m25)
BTW most aftermarket spigot rings are made of plastic, and I run 14 second quater mile drags on golf wheels with no rings, and drive it on the road on renault rims again with no spigot rings. not having a pop, just my personal experience in these matters
Posted: 26 Jul 2007 01:15 am
by Roop
This thread is interesting. I tried to use a set of 4x100 Vauxhall rims on a drift day and lost 5 wheel nuts within 3 laps! They felt like they had torqued down, but then came loose as soon as it was driven. I thought this was due to the pitch of the face on the nuts not matching the wheels, but what else could it be?
Posted: 26 Jul 2007 01:20 am
by 340GLT
i would say it was the angle of the taper on th nuts to rim surface!!
Posted: 26 Jul 2007 07:50 am
by huskyracer
The spigot bore on the wheels you have is proberbly too small, some of the vauxhall rims have a very small centrebore which hangs up on the hub just before the wheel sits flush on the hub.
Posted: 26 Sep 2007 12:49 pm
by 480_rocket
I'm getting some custom made spigot rings from 52.1mm to 57.1mm if anyone is interestted, as it'll probably make sense to make a batch.
Posted: 26 Sep 2007 02:21 pm
by 340GLT
Just had some made myself mate for my comps. How much they gonna cost you out of interest and what will they be made of?
Posted: 26 Sep 2007 03:55 pm
by 480_rocket
Oh, where did you get yours made? Mine are going to be made from some tough PVC material, and probably be about £15-£20 a set inc P&P.
Posted: 01 Oct 2007 11:21 pm
by Ricatron
hello people im new to V3M and this thread has been a good read
i have a 343 which i just bought and i have a BMW e30 335i (engine from a e34 535i) i heard that golf alloys fit bmw's so if golf wheels fit a volvo will bmw alloy fit a volvo?
i thought about using the bmw 205/55/15 7j on the volvo but i think they will be too wide but my 14ich bottle tops will sit nice if they fit?
any idea
Posted: 02 Oct 2007 09:32 am
by Ronnie
Bimmer E30 wheels should fit - but don't know anyone on here who's actually tried it yet
