Engine Question (9-series)
Steelballz
Re: Engine Question (9-series)
hmm, sounds good to me!!!more smoke off the tyres, which will last even shorter...
Steelballz
was just thinking the other day that I might leave the HPT actuator for another while...stil welded up the diff on tuesday, time to smoke some tyres
:D:D
- foggyjames
Definitely do the actuator...it's rude not to
Honestly, it's so simple, and makes quite a big difference.
Look for any "FT" engine with a Mitsubishi TD04-13C turbo...B200 or B230.
Steelballz
@foggyjames: if its a TD04 turbo I'm looking for, couldn't I also try getting a standard Impreza WRX actuator, as they have a TD04 standard VS the Evolution with a TD05..?
I'm picking up -95 940, 2.3T (8v) on Saturday..
Got "spare" manifold with T3 to go on, bigger IC, 3" dwn pipe and side exit..DONE!!
- foggyjames
As long as the Scoob's actuator mounts in the same way, that'd work fine. Do they not have ECU / solenoid controlled boost? Normally, those setups use a really weak actuator...
- foggyjames
I suspected as much. Surely Volvo HPT actuators for a 13c aren't that rare...?
Steelballz
over the pond in Ireland 940's aren't exactly commonplace in the scrappie'sfoggyjames wrote:I suspected as much. Surely Volvo HPT actuators for a 13c aren't that rare...?
PM on the way...xtrmjks wrote:If You need actuator, PM me!!
btw I assume its an actuator for a higher PSI boost, will the ECU from the B230FK compensate for the higher boost, or will it run like crap?!?!
- foggyjames
You should be ok up to 10, maybe 12psi. Beyond that you need to look at chips, bigger injectors, raising the fuel pressure, etc. There's plenty of info on Turbobricks.
Steelballz
just joined turbobricks there now, and used you as a referralfoggyjames wrote:You should be ok up to 10, maybe 12psi. Beyond that you need to look at chips, bigger injectors, raising the fuel pressure, etc. There's plenty of info on Turbobricks.
now to read through the forum's, and ask for more definite info and what parts can be used etc.
p.s. thank you V much for the link
Steelballz
ye all havent heard off me in a while...got it home since, and also blew a diff (3rd gear messing LOL) since...
finally got a new diff (2 people in the whole of f*cking republic of ireland had one..!!!!)
still on the lookout for a HPT actuator and MBC, if anyone has and lying around f/s...?
- foggyjames
My housemate had a couple of used MBCs...I'm sure at least one will be for sale.
I don't have a line on an actuator right at the moment.
