Sorry about the swearing.. I couldn't spot any rules anywhere so did a google
Site search for the word f**c... Got loadsa results so assumed it was ok. I'm used to forums full of swearing is all, but I'll stick a lid on it!
Fiddlesticks:D
Fuel lines / pump replacement.. Cool. I assume there's no major trouble there, being a fairly modern car.. Replacing the whole fuel line on a beetle can be a PITA, it runs through the central tunnel and there's no way of getting at it! What pressure should a 'high pressure' pump be putting out? Would a 6.5 - 7.25 psi / 35 gallons per hour Facet pump do the trick?
RE: the heaterbox.. Thanks for the pics, I can see how that could cause some problems.. How much it it to have the manifold sorted?
I may live without heat for a while if it's pricey, I do have to keep it cheapo if possible:)
Also, not reeealy important, but I'm curious now.. Does the spare wheel still fit under the bonnet with a 16v conversion?
trabitom99 wrote:A very important feature of a V300. I agree entirely:
^Sweeeeeet:D
I'm impressed with this forum so far by the way..
