This one. Nowt to worry about.Chris_C wrote:It's normally the output shaft bearing from the bellhousing rather than release bearing (I think....)
Hiya volvoniuns
- filthyjohn
Re: Hiya volvoniuns
Re: Hiya volvoniuns
mine does that mate, if its idling when cold. it just the engine shaking and making the manifold hit the heatshield. nothing to worry about
- griffo20022
Re: Hiya volvoniuns
Another one here which rattles too, dont worry about it dude. Although if it bothers you I can't imagine it'd be expensive
'90 340 1.4 Vince!
'94 BMW 325i Saloon
'94 BMW 325i Saloon
- volvodspec
Re: Hiya volvoniuns
input bearing of the gearbox has the same weakness as the output shaft bearing from the bellhousing, don't worry about any noise rattle etc on idle with the clutch off.
rattle with applyed clutch (release bearing) is a different story, this may cause problems when changing gear.
if the bearings on the prop are really really worn you notice this at high rpm, makes the entire car vibrate like crazy
Re: Hiya volvoniuns
it's smooth at high revs
should be ok then, i'll let it alone... wait till it's fully knackered before doing any work... that's the idea innit?
