360 LSD.
Re: 360 LSD.
I would say must be 12.9 grade. I'm sure the 10.9 would work but how would you feel if the bolts snapped and destroyed your nice new diff?
Re: 360 LSD.
Most bolts 30mm and under are fully threaded, normally only bolts 35mm and over have a shank so you might be best with longer bolts and cut them down
FREJ
Re: 360 LSD.
Post by FREJ »
perkabrod wrote:Yes that type of bolt would be great. It was a lot more difficult than I thought to google specific bolts... maybe the best thing to do is like you seem to have been doing, namely, finding a bolt that's used in a car that uses M12, 1.5 pitch quality 12.9 and just hope they are longer than 30 mm.
Gonna be looking.
Also FREJ, I dropped the distancer into the crown wheel but some force was needed to push it so I didn't want it to get stuck. Just wondering in case yours fitted loosely enough to have it fall out if you held the crown wheel upside down?
The distancers' thickness looks good in your photos... Hope to be able to solve this so that I can run torsen diff this summer :360:
Good work with searching for bolts!
The distancer of my Torsen have been dropped successfully into one crown wheel as showed on this pic.
But in another crown wheel it didn't fit. So it is to tight specs on the Torsen part I believe. But nothing that a lathe can´t solve easily though.
Volvo 360GL 1987, B230 with high comp. 531+V-cam
MS1 V2 + 337cc injectors, fuelpressure 3,5kg. Running Ethanol since 2004
Timo Extractor Manifold 4-2-1
http://www.300power.com
FREJ
Re: 360 LSD.
Post by FREJ »
miniswift, what is the ratio, that this torsen differential can transfer momentum with? Is that known? Just curious!
miniswift
Re: 360 LSD.
Post by miniswift »
I'm in Japan at the moment.
Once I get some info from my supplier, I will let you know.
Atchi
perkabrod
Re: 360 LSD.
Post by perkabrod »
I would be interested in some specs too :D
Anyway, in case any future diff would come in 1.5 thread pitch you can follow progress here, we've got bolts now that hopefully will do the job
http://www.300power.com/forum/index.php ... #msg107817
Re: 360 LSD.
That thread makes good reading, glad you have found a solution guys
miniswift
Re: 360 LSD.
Post by miniswift »
Hi,
I got 3 of them ready now.
I will let people who showed interest first for first refusal.
Perkabrod
madseb
smchris
Atchi
perkabrod
Re: 360 LSD.
Post by perkabrod »
I haven't fitted mine yet but just got hold of a gearbox+diff so hopefully soon I will install it.
Just curious, do you know if the ones you have now have correct pitch (1.25) and if drive flange possibly fit better?
I sorted some 1.5 pitch 12.9 quality bolts btw.
miniswift
Re: 360 LSD.
Post by miniswift »
I will find out when I get it.
I will supply correct bolts if the made it wrong again.
Atchi
360beast
Re: 360 LSD.
Post by 360beast »
Who makes these diffs?
miniswift
Re: 360 LSD.
Post by miniswift »
contact in Europe who makes gearsets and others for racing teams.
It is my secret who actual they are!
miniswift
Re: 360 LSD.
Post by miniswift »
Hi,
3 of LSD has arrived.
Here it is!
So who wants it?
Atchi
|2aebird
Re: 360 LSD.
Post by |2aebird »
I want one please!
miniswift
Re: 360 LSD.
Post by miniswift »
By all means, you can.
You have to give me your address so that I can get a shipping quote.
Let me know what you want to do.
Atchi
