Kessy mk2 340, no more scrap yard fun
Re: Kessy mk2 340, Leaning!
I know it baffles me too. I can only assume that it decides to sit one way or the other. Probably find my fronts are sagged on one side which translates to the back also.
sven360
Post by sven360 »
filthyjohn wrote:Magnumpi got owned thinking his car was leaning but it had a front wheel parked on a lump LOL :lol:
If you're gonna check ride height make sure it's on a flat and level surface. I find it hard to believe that one spring would sag noticeably more than the other, they'll have come off the same machine consecutively, made with the same batch of metal on the same day, to the same spec!
http://i1236.photobucket.com/albums/ff4 ... bottle.jpg
Write it in your heart.
The code of the West.
theo2468
Post by theo2468 »
sven360 wrote:I agree re weak spring,however,I disagree about the spoiler.The smaller mk2 spoiler is sweet.
The later whale tail sucks real bad. sm81
doesnt lean much on the front compared to the back
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
sven360
Post by sven360 »
Weak leaf spring.
That be what I was meaning.
theo2468
Post by theo2468 »
if i measure from the floor pan to the leaf spring on each side that should show me that it's sagging right?
hopefully if i put my lowering blocks in it will change it, or im going to have one scrapping side ha
Post by filthyjohn »
^^^ as long as it's on a FLAT, LEVEL surface yes. Lowering blocks will do nothing to improve things.
Nimminz
Post by Nimminz »
Cant help with the leaning, but i'd say keep the spoiler, back end looks a bit plain otherwise imo
Evoman
Post by Evoman »
Ye, your best off taking some measurements before you go assuming things, but if the shock isnt collapsed it would be the sring. Are you driving it around much?
sven360
Post by sven360 »
Shock absorber,the clue is in the name.
How would a weak shock effect how a stationary car sits??
Or am I missing something here.
Evoman
Post by Evoman »
if its leaked? i im not sure if it would collapse tho
theo2468
Post by theo2468 »
it happened to jon, his shock collapsed and he had a lean
L14MNP
Post by L14MNP »
S(h)agged spring.
Here's how mine was sitting with the same issue.
Mine is more noticeable due to smaller diameter wheels.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
theo2468
Post by theo2468 »
leaf spring yeah??
L14MNP
Post by L14MNP »
Aye.
STREETO WITHDRAWL
theo2468
Post by theo2468 »
fuck sake, cant be bothered to change my leaf spring
