Page 16 of 31
Re: Performance parts cat
Posted: 09 Jul 2009 06:53 am
by pistonpen paultje
I think most of the F7p guys building one, want this, as the original F7p/r needs to be cut and welded...
Posted: 13 Jul 2009 05:18 pm
by filthyjohn
All the clio boys reckon the standard williams manifold is too restrictive for 160hp+, so a better option would be nice. Mine has cams now so I think I'm reaching the limits of my homemade crappy exhaust.
Posted: 03 Aug 2009 06:46 pm
by stew
sorry for whinging :oops:
Posted: 03 Aug 2009 10:13 pm
Dai sometimes gets kept away from the forum for differing reasons, have you tried sending him a ring or a text? His no should be the first post, and he will always get back to you a lot quicker that way.
Posted: 03 Aug 2009 10:35 pm
by stew
**Edit** Seems I was being an impatient d1ck :oops: stuff arrived today sm4
Posted: 05 Aug 2009 11:12 pm
Stew,
did you get my PM about UPS's balls up. Both your and Tom's order did not get collecting and I had to chase them twice before they eventualy turned up. They have been very reliable upto now. Glad everything has arrived with you ok now.
Regards
Posted: 06 Aug 2009 06:40 pm
by stew
I didn't mate that's the reason I was worried, no problem though.
While I have your attention there are 2 different lenght bolts in the sets I have is that normal and will all become apparent what goes where when I fit the blocks or are all 8 supposed to be the same lenght? Ta
Posted: 06 Aug 2009 11:47 pm
At one end of each side there is a 10 mm thick spreader plate. The longer bolts are to go through that end.
Posted: 28 Aug 2009 10:23 pm
by mrsoundcraft
Hi, whats the current situation with special improved topmounts?
Ive broken a thrust bearing and could be tempted to replace the whole lot, because the saxo VTS thing isnt going anywhere.
Sorry Just checked, thought these were still in R+D
Posted: 29 Aug 2009 09:30 am
Just a quick one Dai, am I right in thinking you now sell adjustable fronts?
Posted: 29 Aug 2009 09:39 am
by volvosneverdie
SteveP wrote:Just a quick one Dai, am I right in thinking you now sell adjustable fronts?
Think they're on eBay?
So I'm guessing yes.
Posted: 29 Aug 2009 11:33 am
mrsoundcraft wrote:Hi, whats the current situation with special improved topmounts?
The top mounts are available but to order only. The big advantage of the ones that I make are the ride height can be kept low. Using nissan ones or others will lift the front end over 1"
Posted: 29 Aug 2009 11:36 am
The front inserts have been available for a month or so now. I can do them in the std height version for use for use with original or rally springs and I do the more common shortened version for use with lowering springs. The shortened version eliminates the need to clamp the spings to the cups.
Posted: 27 Sep 2009 10:21 pm
by Auntie had several
Dai, posted you a cheque weeks ago and heard/received nothing. Can you tell me what's going on? Tried to text but heard nothing either. Cheque was for 2" lowering blocks and 3" lowered front springs........Jonny
Posted: 28 Sep 2009 09:46 am
by Cutler
same for me, send you the money (more than 450€) for a complete suspension upgrade and heard nothing since.
drop me a pm an let me know whats going on pls.
thanks.
