Page 17 of 22
Re: Another one..
Posted: 04 May 2009 10:12 pm
by jtbo
Remember that noise != power :wink:
My car is very loud too, but I will build new exhaust that flows well and is still quite quiet, nothing is more bitter surprise than silent flash, when it comes to traffic light eliminators.
Re: Another one..
Posted: 05 May 2009 10:18 am
by xtrmjks
jtbo wrote:Remember that noise != power :wink:
Mine's got 2 (small) silencers, when @ 6K and over, it's HOWLING!! :D
Re: Another one..
Posted: 05 May 2009 10:27 am
by volvosneverdie
I know.
I can hear it.
From Newcastle!
Re: Another one..
Posted: 05 May 2009 03:33 pm
by jtbo
Mine has one tiny at middle and backbox is such type that if I look from one end I can see trough it from another side, it does not restric flow, but also not much restriction of sound, impossible to drive 400km in it without ear plugs.
One reasons why I need full new exhaust.
Re: Another one..
Posted: 05 May 2009 03:47 pm
by xtrmjks
:D Mine are 2x 2.5" Jetex (Simmons) short boxes..
just took it around the lanes.. :D ("Hills are a live with sound off...)
Re: Another one..
Posted: 05 May 2009 03:48 pm
by volvosneverdie
xtrmjks wrote::D Mine are 2x 2.5" Jetex (Simmons) short boxes..
BBBBWWWWWWWWWWWWWwwwwwwwwwwwwwwwwwwwwwwwarrrpppppp!
Re: Another one..
Posted: 06 May 2009 03:10 pm
by xtrmjks
Here is some new stuff from today,
Watts linkage,
before,
after, (DTM mirrors..)
..also sorted cam belt, as it was running close to outer edge of top pulley. fitted spacer.Sorted
Might do new exhaust tomorrow... :D
Re: Another one..
Posted: 06 May 2009 03:13 pm
by 340GLT
Watts is in the process on the grey car......
Re: Another one..
Posted: 06 May 2009 05:13 pm
by xtrmjks
KILLED IT!! seems like diff exploded!
hit island @6K on 3rd..
me and some mates were taking some drift videos for Driftworks..
It's back at unit, will repair it tomorrow. Got plenty of diffs and boxes.. :D
will post videos..
Re: Another one..
Posted: 06 May 2009 05:15 pm
by Cutler
@ how much bhp?
Re: Another one..
Posted: 06 May 2009 05:42 pm
by xtrmjks
Std gearbox don't take much (cluthing @ high revs)...I was me "being stubid".. :D
Re: Another one..
Posted: 06 May 2009 05:45 pm
by xtrmjks
Re: Another one..
Posted: 06 May 2009 11:03 pm
by volvosneverdie
dude!
if you cant play nicely with your toys, they will be taken away! :lol:
vids please!
and well done for not dying man. :D
Re: Another one..
Posted: 07 May 2009 04:06 pm
by volvosneverdie
xtrmjks wrote:
volvosneverdie wrote:Dude, i saw those too!
The polished ones?
Awesomness factor of about one billion %
Yeah! Would look good on 300, I recon..
http://www.pistonheads.com/SALES/1016871.htm
bumped into these............................................. :o
Re: Another one..
Posted: 07 May 2009 05:34 pm
by jtbo
It was to be excepted that diff or some other driveline component will fail, you pushing something between 160-180hp with healthy amount of torque?
I don't remember if your diff is welded or not, but if not, then it can be those small gears in diff that give up in such situation. That diff does not like from wheel spinning without welding it. After welding it, there are more places that will fail, shaft between box and diff, gears of that shaft, transmission main shaft, happens also at 3rd gear that box case start to deform under stress and axles moves inside box, front of gearbox there is that clamp which fails if bolts of it become loose which they tend to do sometime, driveshafts can also fail, some VW Transporter joints were compatible if I don't remember wrong.
Easiest way to get something broken is spin wheels at high revs and hit small bump which suddenly increases grip, there is lot of inertia and even strong part can fail, remember weight adds to grip quite lot so when car body comes down or ground up, there is chance to get thing broken, but xtrmjks knows all this already, I believe :D
Have you managed to test tensioner spring yet?
