Another one..
Re: Another one..
Post by filthyjohn »
That's the cheapest I've ever seen turbos.
xtrmjks
Re: Another one..
Post by xtrmjks »
jtbo wrote:It was to be excepted that diff or some other driveline component will fail, you pushing something between 160-180hp with healthy amount of torque?
I don't remember if your diff is welded or not, but if not, then it can be those small gears in diff that give up in such situation. That diff does not like from wheel spinning without welding it. After welding it, there are more places that will fail, shaft between box and diff, gears of that shaft, transmission main shaft, happens also at 3rd gear that box case start to deform under stress and axles moves inside box, front of gearbox there is that clamp which fails if bolts of it become loose which they tend to do sometime, driveshafts can also fail, some VW Transporter joints were compatible if I don't remember wrong.
Easiest way to get something broken is spin wheels at high revs and hit small bump which suddenly increases grip, there is lot of inertia and even strong part can fail, remember weight adds to grip quite lot so when car body comes down or ground up, there is chance to get thing broken, but xtrmjks knows all this already, I believe :D
Have you managed to test tensioner spring yet?
I PM'd You about cam belt tensioner spring..
Diff was welded, I swapped it today for another one (welded again.), there was big chunk missing from ring gear and dent in diff cover plate.. :D Housing is o.k. Won't be doing that again!!
new exhaust is on, took ages to make 2.5" to clear propely..sound good!! :twisted:
will post pics!!
Re: Another one..
xtrmjks wrote:I PM'd You about cam belt tensioner spring..
will post pics!!
Must be eaten by byte monster that lives inside these computer machines, PM has not arrived :shock:
Nicely done with getting gear broken, it requires bit more torque than other parts usually :mrgreen: Never broke anything and you haven't driven it properly, right? :D
We need that video sm18 :mrgreen:
Re: Another one..
Videos dude!
Re: Another one..
filthyjohn wrote:Videos dude!
+1 billion
xtrmjks
Re: Another one..
Post by xtrmjks »
New exhaust, 2.5" with rear exit, is on..
..like it better! quiet on low revs and "town driving", but when you floor it, BAAAABRRRR!!! :D
Massive industion noise from carbs!!
First seemed running lean, with new exhaust (more back pressure??), so I swapped for bigger jets..lot more go!! :D
Cutler
Re: Another one..
Post by Cutler »
nice progress on your car!
i sneak in with a question. how did you get the grill so clean?
on mine it looks like it will be un-even when the volvo batch is removed. hope you can follow me on this one.
Sideways @ flat 2 the mat forever!
Rally-gious!
Re: Another one..
Post by 340GLT »
You have to cut and shut 2 grill together to make a totally smooth one.
xtrmjks
Re: Another one..
Post by xtrmjks »
340GLT wrote:You have to cut and shut 2 grill together to make a totally smooth one.
That's it!!
Some new pics,
xtrmjks
Re: Another one..
Post by xtrmjks »
Picked up some new wheels, (before refurb..)
Proper old magnesium rally wheels!! :D
I recon these will siut 300!
Re: Another one..
Love it!
xtrmjks
Re: Another one..
Post by xtrmjks »
little update..last "niggles" been sorted and it's now running sweet.
I've added Whiteline ARB and race engine mounts. I'm taking it off road after PPC in the park, for 16v Turbo and M90, with 240 axle to go in..
Re: Another one..
xtrmjks wrote:little update..last "niggles" been sorted and it's now running sweet.
Crazy man, hmm have I said that before? Anyway, Crazy man :mrgreen:
Will you mate diff+box or are you going to put box to front of car?
Mating box + diff provides bit more challenge, but then again it maintains part of 360 spirit tad better, that one bloke did such for his BMW V12 twin turbo thing, I believe it was. Fuse did post pics to general discussion quite some time ago, perhaps worth to take a peek as there were some progress pics.
Re: Another one..
dude, youre sick man, sick!
I cant wait... :D
xtrmjks
Re: Another one..
Post by xtrmjks »
I'm going for more common box+prop+axle set up..
It was Peter, from 300Power..
