my b230fk into a 360 build thread, winter refresh!
- foggyjames
Re: my b230fk into a 360 build thread
I'm still working on it. Will let you know...
Have you rung any of the specialist Volvo breakers?
if you find me one james you will be my hero lol, will pay you for your time pal,
and ive rang the closest 2 chris, will get in touch with a few more if i can find any,
anyone know any volvo breakers?
- foggyjames
Try CP motors in Tamworth, Braydon Motors. Salvo. Flywheel from a 240 or 740 with a B200F or B230F...or a 940 with one of those or a 200/230FT...all with either an M46 or M47...if that makes sense? Most sources will be 940s, but late (1990+) 2/700s will have one too.
cheers will do, what years did the 740 and 940's have one?
- foggyjames
240: 1990-1993 (Introduction of 'F' engines to end of production)
740: 1990-1992 (Introduction of 'F' engines to end of production)
940: 1991-1994 (Range introduction to introduction of M90 gearbox)
It's basically anything with an 'F' engine (whether a B200 or B230, and a plain F or an FT) with an M46 or M47 transmission.
cheers mate,
not even had chance to do anything else
not updated this in a while, everything is done now includeing both lumps out ready for the conversion, apart from flywheel
will get an update done soon,
can anyone help me with flywheel?
Have a the 60-2 induction pickup machined into a flat fly or use a trigger wheel dude?
I may part with the LH2.4 dog dish fly I currently have on the B230, but it won't be for a bit yet, as I need to see if it will work with the pressure plate I intend on using.
Sorry!
Sorry!
STREETO WITHDRAWL
INTO BURNOUTSsince1982
gonna sound dumb but what do you mean by 60-2 induction pickup machined into a flat fly or use a trigger wheel?, and no probs, let me know if you do,
whats the reason behind not useing the dul mass one? is it that its to big for the bell housing? is there any way it can bbe modified to fit?
60-2 is the trigger pattern for LH 2.4, to have the induction pickup machined into means to machine the trigger pattern 'dimples' into a flat fly a non dual mass flywheel or use a trigger wheelA trigger wheel is like a flywheel but doesnt go in the same place, you can put it say at the front of the engine. It acts in the same way as the flywheel as regards timing for the ignition. Obv. the crank position sensor needs to be moved to it aswell.
I'm planning to change just the injection and ignition system on my car from the LE-jetronic it is now to LH2.4-Jetronic which is what you have on your new engine. As i'm not moving the engine in and out, it would be a lot of extra hasstle to have to change the flywheel for a LH2.4 one (if i could find one!!) so I'm planning on using a trigger wheel.
I think it's too big why the dual mass one doesnt fit, don't think i've ever head of it being made to fit.
ahhh cheers mate that clears alot up, might have to look into this trigger wheel, its just the flywheel thats holding the conversion up
need to get it sorted asap
- foggyjames
Having it machined is likely to be super-expensive...and you'd need to start with a plain 240 dished flywheel. Yeah, the dual mass is way too deep to fit.
I'll give my mate a call...see what he can do...
cheers james would be great if you could sort me out, lie i say its just that holding me up now, a mate of mine knows a company that can do stuff like that so if worse comes to worse i might see how cheap he can get it done
