Page 3 of 3
Posted: 18 Jun 2005 04:40 pm
340GLT has one for sale.
Posted: 18 Jun 2005 07:17 pm
by aukki
Looking for another one because:
econometer
Posted: 18 Jun 2005 08:15 pm
Doesn't that just push back on?
Posted: 18 Jun 2005 08:19 pm
by aukki
The plastic axle is broken. :( sm14 sm25 sm58
Happened today:
Here is new axle coming:
New axle
almost all plastic
Posted: 18 Feb 2007 04:54 pm
by trabitom99
foggyjames wrote:Delayed lights = The interior light doesn't switch off as soon as you close the door on a GLT. Someone really must tell me where that relay is sometime!
Just thought I'd update this post, cause I couldn't find anything on the interior light delay relay (E12) in the forum previously ...
I've just fitted a relay from a GLT for "delayed lights" to my GLi - the location is just behind the instrument panel (LHD, so possibly behind the glovebox on RHD cars). Access is easy, just remove the facia panel underneath - the fitting (socket?) for the relay was already there with a green wire just bridging it.
Posted: 18 Feb 2007 07:52 pm
by petefarrell360
That's very interesting! Good work on letting everyone know! It's something that I didn't think would bother me too much not having it on my 340. However I tend to find myself either opening the door and leaving it open when I get somewhere to find things in the dark, or forgetting to switch the light off after turning it on manually.
If it's that simple then I'll remember to do it when I get to removing the relay from one of my 360 GLT's I've got to break up.
Posted: 18 Feb 2007 11:43 pm
Right...so we're looking for a relay socket with a green bridging wire...sounds easy :)
Posted: 18 Feb 2007 11:52 pm
by trabitom99
petefarrell360 wrote:However I tend to find myself either opening the door and leaving it open when I get somewhere to find things in the dark
Me too - I tend to leave the door open when looking for the keyhole for the ignition key. Still can't find it in the dark, even after all this time...
foggyjames wrote:Right...so we're looking for a relay socket with a green bridging wire...sounds easy :)
Well it was on mine :) Here's a picture of the relay socket as it was before I stuck the relay in (taken through the instrument panel surround - in the right of the picture you can see the speedo cable, I unfortunately damaged the bayonet connector while removing it from the back of the instrument panel)
... and here's the relay you'd need:
Posted: 19 Feb 2007 12:20 am
Top info there :)
Posted: 19 Feb 2007 01:53 am
by petefarrell360
Indeed, pictures help a great deal! I shall see what I find, I'm imaginging it's on the steering column in a RHD 300 as well. On the donor GLT, was the relay clipped onto one of the brackets on the steering column? I'll have to have a look on my 340, and compare what's on my 360.
Posted: 19 Feb 2007 06:36 pm
by trabitom99
petefarrell360 wrote:On the donor GLT, was the relay clipped onto one of the brackets on the steering column?
I can't be 100% sure because I bought the relays seperately and didn't remove them myself, however the delay relay was definitely clipped to something as there's still part of the broken-off clip embedded in the relay housing (see top of the relay picture). Sounds feasible ...
Posted: 19 Feb 2007 11:03 pm
by petefarrell360
Ah yes, I see that now, it looks like the right sort of thickness for the metal clips, same colour. I'll check them out when I get a few minutes. That reminds me, the GLT kick panel below the steering column if off at the moment as I had to entice the indicator flasher relay into working for the MOT after it had stood for a while!
Posted: 20 Feb 2007 12:53 am
I had to do the same there Pete. Seems to be a common problem after sitting!
Posted: 20 Feb 2007 08:45 am
by redline
hasn't this all gone ever so slightly
OFF TOPIC lol
