I have installed a Megasquirt ECU, and now it runs fine over 60 mph.
I found out that it was to lean mixture that was the problem.
Now I have a new problem! It's my tach signal.
For those how has experience with megasquirt in a 360 with renix, from where have you taken the tach signal for the ECU.
I get my tach signal from the original Bosch connector and when i rev the engine over 3300 rpm's, the tach signal jumps around.
What have you done to make the signal steady and spike free?
I have jumped D8 and not installed the DAVE cap.
If I install the DAVE cap. the tach signal from the renix dies
I have also tried with a 1k, 10k and a 33k resistor in line with the tach signal. The 1k makes the tach signal jump around already at 3000 rpms, the 10k and the 33k kills the tach signal
What can I do?
Regards.
Peter
DK
