Re: White 340 1.7 Martini
Posted: 19 Dec 2015 02:04 pm
thanks, bogbasic, much appreciated and raises the level of encouragement
Sooo, i went to buy a set of piston rings back then. One oil ring was broken from the box and dealer refused to exchange so i had to buy 5th set of rings. With everything ready for the short block, i decided to take the head out to check and have rings fitted.
Bores on 4xx engine were acceptable, still little hone left and the diameter was on the loose side of STD measurement. And the short block was successfully assembled. Oil clearance on the main bearing was from the memory 0.029mm - just a perfect measure between 0.028 and 0.045 as written in the book.
Got new clutch disk from lada riva, absolutely same size as volvo, including splines. Put flywheel and pressure plate from 340 and a new disk back in. Also got new clutch release bearing, but found mine to be in perfect shape so left it as is. And another thing i decided to try is to fit an electronic ignition from newer lada model. It's basically a GM ECU, revised and called January here. I could not find volvo's ignition ECU from 1.7 back when mine went bad so as temporary solution fit 1.4 ignition module. With Lada's ignition i'll get fully electronic ignition with two coils and i'll be able to correct ignition map online. So i bought a pulley with 60-2 timing disk and had the timing disk welded to volvo's crank pulley. Also bought crank sensor. MAP sensor, ECU, coils and wires are pending.
Then was the time for the head. 4xx head was in the same poor state as 340's one. So i took a friend and pulled a head from his parts car. Picture below shows exactly how it went - in the night, deep into suburbs, with temperature below zero and all that stuff. Unfortunately this third head was also worn out so i bit the bullet and sent my original 3xx head to recondition. Received it back with new valve guides, new valves, guides milled for new valves and the main plane a bit milled (0.15mm at most). Assembled it all with new seals.
Upon assembly had a little problem with mixing and matching parts from 124 and 125 teeth belts from 4xx and 340, but solved it by putting the whole set from 340. So this is where i'm now. Engine was assembled, and now i need to tow the car to paint booth to refresh the paint under the bonnet, probably will refresh the bonnet as well. Hope it's all complete before new year=)
Thanks for reading.
Thanks for reading.
