Page 3 of 3
Posted: 03 Mar 2006 01:49 am
The driving computer gives an almost perfect speed read-out, which (since it's set from the trip meter) goes to show that the over-reading is needle-error, rather than the mechanism as a whole being bad.
Posted: 04 Apr 2006 09:47 pm
I've borrowed my dads road angle and that indicates that the 440 spedo is reading just over 10% slow and the original is runs about 10% fast.
I think I will get the 400 one recalibrated to the correct speed now I know exactly what it should read.
If I had stock wheels and tyres it would probalby read spot on.
Re: 'How to Guide' How to fit a 140MPH speedo
Posted: 05 Oct 2013 09:54 am
by BMR
Topic kick......
I used this guide for the speedo change in my 360turbo.It's realy a piece of cake.....if you don't do anything anything else......
Testing showed a diference of about 3 KM/H negative which is ok(tested with a gps) .Probably due to to the bigger wheel diameter.
Posted: 05 Oct 2013 10:49 pm
It is a good upgrade and saves running off the end of the speedo a lot of the time
Posted: 09 Oct 2013 08:58 am
by 340GLT
That brings back memories!!
Posted: 12 Oct 2013 01:24 pm
by BMR
340GLT wrote:That brings back memories!!
Wanna talk about it?
Posted: 13 Nov 2013 12:47 pm
by Joe Danger
JUST !
Be careful about using "the fork trick".
I've changed the dash light in my brothers honda (adding 26 LED's inklusive the normal ones on the back), and used the fork trick.
- but it damaged the rev needle motor, so now it's fucked...
- easy fix tho.. but annoying money...
Posted: 16 Nov 2013 11:41 am
by MCHUDD
Hi all
That turbo 360 just looks a CLASS ACT.
