yours was the last of the 1.7 line; the B172 was kicked out as soon as the 440 started to sell.
so; all 340 1.7 are the flimsy ones.
[edit]
@pettaw; OK at least you convinced me that the manifold is prone to warping as well. thats a good thing to note.
I know the volvo dealers in Holland had the option to fit a very special soft insulation flange, wich would form itself to any way the carb and/or manifold had been warping, and still seal off good.
This 'super-gasket' was very expensive, but not as expensive as getting a new carb.....
BTW I think one might be able to cure the manifold warping with the same method I described for carb base flattening.
Uneven (odd) idol rate
- antiekeradio
- antiekeradio
- antiekeradio
Minus 10 points.... (for those that don't follow the point's thing, it's a random from (I think) John_360 and a non standard battery at a BKV comp)
- antiekeradio
