What engine would you consider upgrading to...
Which Engine Would You Consider Converting To:-
Poll ended at 01 Jan 2006 10:21 am
B200ET 2.0 Turbo (160bhp)
1
5%
B200FT 2.0 Turbo (155bhp)
1
5%
B230ET 2.3 Turbo (182bhp)
2
10%
B230FT 2.3 Turbo (160bhp)
2
10%
B230E 2.3 (130bhp)
1
5%
B230FB 2.3 (136bhp)
1
5%
B234F 2.3 DOHC 16v (155bhp)
1
5%
B18FT 1.7 Turbo (120bhp)
3
15%
B20F 2.0 8v (110bhp)
0
No votes
F16ie 1.8 DOHC 16v (137bhp)
0
No votes
B200E Turbo conversion
3
15%
Standard - The way the factory intended
3
15%
None of the above
2
10%
Total votes: 20
If you've got enough power, you don't need skinny tyres :) Low power low grip certainly works, but there's a limit to the speeds you can drift at. Maybe that's a good thing?
340s are pretty damn light. A 3dr 1.4 is 900-950kg...which for a car much closer to being the size of a Sierra / Cav than an Escort / Astra is a pretty good effort...especially given the far superior structural integrity of the bodyshell (just look up the safety rating for a Sierra :shock: ). Drift safely kids :D
Lonewolf
Post by Lonewolf »
I'm going Non volvo here for the sake of uniqueness and cause i'm a crazy bugger.
Choice 1- 20B Twin Turbo (200hp) With the ports Filled in and replaced with peripherals, Blueprinted and Modify the turbo's... conservative guess would be 800hp but might probably push 1000 if done properly... oh and some nos on top of that.... for good measure... ok maybe thats a little too extreme
Choice 2- LS1 + a good set of extractors... put the car on a really big diet on the front end to keep weight distribution acceptable- Battery up the back, Dry sump, remove aircon, heaterbox completely etc... it'd own all at the stoplight wars and would sound pretty pimp too.
Choice 3- 3s-ge (175hp) When i put a 3s-gte in my MR2 (with a beams head, 260hp) i'll have a spare engine in top condition... port the head, up the compression a bit and a semi-lumpy camshaft... maybe 200ish... and this one is an actual pssibility too...
-1st (Outright) Armidale
mefistofeles
Post by mefistofeles »
Take a 5.3 liters Jaguar v12 from XJS. 299 Hk!
Volvo 340 with v12.
What happened to the PRV, and why not a redblock? Otherwise, cool :) Rotaries must be big down under - most of you guys seem to rave about them. If you strip the AC, gimme a PM...;)
Japper
Post by Japper »
Is that 340 V12 for real? You have to be a complete frootloop to put a 600 kg engine in the front of a 340. Do the back wheels even touch the ground?
Leather, leccy windows and mirrors, snowcap, foglights, open air filter, black roof upholstery. What more do you want? >a 2.3 turbo!
n xntrx volvo
Post by n xntrx volvo »
grizlyadams wrote:wheres the 16v penta 2.5L redblock with truck turbo option sm14 :wink:
Griz
ah, thats so 2005.
howbout a volvo v8 out of the xc?
or a nice d5
go to t-bricks if you wanna learn about getting a car like mine
http://forums.turbobricks.com/index.php?referrerid=3007
98 s70
88 780
87 240 16vt 2.5L
340cbr
Post by 340cbr »
D5?
I'll prefer any otto Turbo motor to a D5...
I have a S80 D5 :?
| 92' 965 Turbo 16v | B204FT - 190hp |
Had: 90' 340 GL + Turbo | B18 FT | Koni's | Alpina White |
n xntrx volvo
340cbr wrote:D5?
I have a S80 D5 :?
nah, you can make power out of anything with enough effort. mines about x3 stock hp (volvo), the other car the same (stang).
98 s70
88 780
87 240 16vt 2.5L
Lonewolf
Post by Lonewolf »
foggyjames wrote:What happened to the PRV, and why not a redblock? Otherwise, cool :) Rotaries must be big down under - most of you guys seem to rave about them. If you strip the AC, gimme a PM...;)
PRV, didnt have luck finding one in good nic, and couldn't find ANY purgeot versions of the block in australia for sale (3.0 SV). Also as satisfying as it would be to do that, it has turned out easier and cheaper to get another car (the MR2 puts out as much as the PRV would have and it is such a nice car)
Rotaries, Not as big as i make them out to be, my dad and uncle used to race them... That and one of my mates has an rx7, and is building up a rx-2 rally car, his dad is helping him as he rallied in the same breed of car. Up north its a popular thing to put a bridge port 13b into the mazda MX-5, it handles AND has some balls. But fuel is also really cheap up there too.
Pros: 1.2L NA engine with 280hp from a simple porting job. 1.3L version would have outdone the 6-7L V8's except for overheating issues. Mercedes made a prototype rotary car (c111) with 2 of the 1.3L bolted end to end. Its a modular engine, you cant add another 2 cylinders to a pison engine easily, you can with rotaries, just need a crankshaft made up. They never got a peak output from the car as it shattered all their megadolar carbon fiber driveshafts... And they sound cool. No valvetrain to break or limit the engine, so they would happily rev out, dad and uncles was really well built and revved out to 20k when fueling became an issue, but it is known about a .1L rotary to rev at 100k rpm for 3 months as part of a bench test for reliability problems. it passed
Cons: They use fuel like you wouldn't believe when ported. 50L would get nathans RX7 about 150k's... He actually got better k's from it when it was being revved out.
They get very hot.
Drivetrain Problems. Mercedes made a prototype rotary car (c111) with 2 of the 1.3L bolted end to end. They never got a peak output from the car as it shattered all their megadolar carbon fiber driveshafts and twisted the chromoly ones like liquorice...
[/RANT]
340cbr
Post by 340cbr »
n xntrx volvo wrote:
340cbr wrote:D5?
I have a S80 D5 :?
You can make the power, but you cannot make it be delivered like ina a otto :twisted:
Lonewolf
Post by Lonewolf »
Oh i digged up a few sound clips (and a vid) from a rotary site on the different ones.
1- This is an awesome engine, 800hp at 9000rpm, 2.6L Nat aspirated
During tuning
http://mrec.rotary.net.nz/media/sounds/787b_3.mp3
0-100 in 2.5sec
http://mrec.rotary.net.nz/media/sounds/787b_4.mp3
2- a small vid of a 20b turbo rx-7 track car, its got some get up and go
http://mrec.rotary.net.nz/media/ts_bat.mpg
3- 1.3L peripheral port
http://mrec.rotary.net.nz/media/sounds/monty.mp3
http://mrec.rotary.net.nz/media/monty.mpg
4- Doesnt sound like a 1L engine does it?
http://mrec.rotary.net.nz/media/sounds/10app_idle.mp3
