360 engine mounts?
about two different engine mounts
i am sure about the two types of engine mounts. my 360-83 and several others have only-rubber-metal mounts. the never type (hydraulic) is worse...had to replace such ones at several occasions...but mine look good even today...no touching the subframe or abnormal noise...two types are interchangeable...seems to me they do not produce the older ones any more these days...sorry...
- RandomHero
engine mount picture
i looked at my car. good image can be taken only from underneath or after dismantling the mount ...the mount itself is not round, i feeled rubber only by my fingers while touching it...sorry cannot make any picture today...
Could you measure the length of them excluding the studs please.RandomHero wrote:I have one pic, i can make some more, i have a spare set in the garage.
- Tero Huikko
If I can get the size I'm sure they will be available very soon in poly. I have a mount already that looks like it is close enough.
first and second engine mounts for two-litre
i have taken a picture of these now. seems to me it is too large...anyways i am trying to publish it here...
recently i bought 86 GL with B200K and replaced one of its engine mounts with another, which i took from my 83 GLT (parts donor car). in the middle of the job i decided to have these items photographed...maybe someone is interested...i also am going to make one custom mount to avoid further problems with these items...photos will be taken too...
Re: first and second engine mounts for two-litre
I'm very interested of the pics of the older style mounts and any custom solution available!mgarageu wrote:i have taken a picture of these now. seems to me it is too large...anyways i am trying to publish it here...
- antiekeradio
- antiekeradio
- antiekeradio
engine mount
i put away the older version steel hanger. used the new one, the older style mount and had to make some minor work on the alloy leg, which is between mount and engine block. the changes were about to avoid the mount to turn while doing the lower nut. sorry about my bad english - i simply cannot remember how the say about the place on the leg, which holds the mount not turning around...somethere else there are lock pins etc.
