Frits 343 1.4 Turbo ic
Frits
Post by Frits »
The engine fits!
Left of the engine will be the place for the turbo. But there is less space than I thougt first. But place enough to make a good manifold. The starter will get it very hot :twisted:
There realy need to come a airintake in the bonnet....
Like I already knew, the original manifold doesn't fit.
I'm happy, but the rest isn't finished yet.....
Looking good - wow a 340 has loads of room under the bonnet without the heater box.
Looking at the turbo and manifold I recon you would get away with making a small coller up to turn the turbo a little and it chould clear. That would save fabricating a complete manifold.
Frits
Post by Frits »
Making a coller up could be a solution, but I m not satisfied with that. :)
I've painting a bit. This is an example how I thinkin of making the manifold.
I probebly have to change the fuelconection to the tank. The fuelfeed is about 4 mm. The return is about 2 mm. I'm not sure, but I think it is way to small..
Nice work Frits, can't wait til it's done :D
Frits
Post by Frits »
Me too :P and I didn't expect that I would learn so much about everything..
Frits
Post by Frits »
Did some things today
A new fuel supply, its a 8mm. I'm gonna use the old supply as the return
THis is the place i fitted the Renix.
And that is how the looks today :P
Frits
Post by Frits »
I'm not sure howe i'm gonna make it.
mefistofeles
Post by mefistofeles »
I love 1,4L Turbos engines!! Good luck with the projekt.
Greetings
David from 300power Club
Pic from a Swedish 340 b14 turbo projekt.
Frits
Post by Frits »
Hi David,
Thanks a lot. It is really a challenge to make a quit heavy car fast with a 1.4 8v engine. But that is just why I love it, doing complete different than anybody else. Thanks for the picture man, I see I want to do it a complete another way. I want to use a intercooler, and a Renault 5 GTT carburettor. Have you more information or a topic-link for me?
Greets Frits
ale
Post by ale »
Hi Fritz!
I'm the builder of the 340 turbo project as you see above.. Nice to see that there are other maniacs trying to scare the 70hp engine up! :D I wonder why you use the renix ignition system? I have swapped to an old fasioned distrubutor from an early 343 with welded "rotating weights" so it should work with turbo pressure. My project is not ready yet, i have to install an electric fuelpump to make it complete and then...... 8)
Frits
Post by Frits »
Hi there Ale!
This engine will be very fast with a turbo. There is a lot availebel for this engine. Other cams, low compression pistons etc.
I kicked the old distributor out of it.I use the renix system from a Renault 5 turbo, special for the turo ofcourse. Besides, it is possibel to connect a knock link to it!! From 85 and on... Renix 209 I believe.
I have further plans for this project.. It won't stay at 120 hp... But that is wat I start with. (A complete stand alone managment is my target!)
But I should make it run and drive it nicely first. Good Luck!
Greetings
mefistofeles
ale
Post by ale »
Good to hear that you is not satisfied with 120 hp but i am more than happy if i get those numbers!! Hummm, Renix from the renault turbo you say.. Very interesting. I think i have to get one of those so i can get more of my engine. My car is made to run fast on slippery ground ( as snow ) and today it is too weak when the 3:rd gear is lit, so i hope this convertation does the job and put the 300 back at the top on snow in stockholm!! It has to run soon before th snow is gone and today i installed my new fuelpump and btr so i hope it will work this weekend! Cheers!
[img][img]http://i125.photobucket.com/albums/p64/ ... papump.jpg[/img][/img]
Frits
Post by Frits »
mefistofeles wrote:You can read/see more here:
http://www.300power.com/forum/index.php ... eadid=2706
Hi Mefistofeles,
Thanx. I already joint the club. I saw that topic yesterday. I can't even read a word swedisch, so its very diffecult for me to understand anything. (It was already diffecult to register :P Maybe I will also open a topic there. :)
Hi Ale,
The B14 engine delivers in the Renault 5 GTT a stock 120 horsepower. I used all the parts of the GTT. Besides, I make a better turbomanifold. Good luck in the snow, I wish it would snow here... It's only one day in a year.
That fuelpomp looks good, I use a extern one. (with the GTT fuel pressure regulator.)
Greets..
Frits
Post by Frits »
If fitted the intercooler today with the help of wouter/antiekeradio. Next to the radiator was a nice place to fit it.
I toke that part of steel out with a (slijptol?)
I also fitted a eletrical fan, because it original had a fixed fan to the waterpump.
That thermostatic flap was used to occur a frozen carb. I will fix it in the right position. :roll:
The frontend is on...
You almost can't see the intercooler. Thats nice because I want to keep the exterior standard :twisted:
Not bad isn't it?
Next to that, I also connected the complete cooling system. I have to find a different place for the cooling barrel. I have enough turbo hoses to complete the inlet system. (Thanks to my dealer here) The turbohoses of modern big engines are a right size to use.
I am considering to make the accu in the back in the car. Than I can make a nice cold place for the airfilter..
cheers,
Frits
