John's valvo *Back on the streets!*
- filthyjohn
Re: Clio 16v engine being a pain, any ideas folks?
Hmm, I'm starting to think the timing could be out like. Anyone point me in the direction of how to check this?
rocker cover has 2 notches like a V above each cam, the makrs ont he cam pulleys should line up with these, and when the crank is at TDC the bolt hole at the side of the block should line up allowing you to lock the crank in position.
bobs your uncle
bobs your uncle
OapEM wrote:It's alive!!!!shift1!!
- filthyjohn
I'm not sure what the problem was really. We checked the timing twice, firing order was right, freed up one stuck accelerator pump, then it barked right up with a bit of a push. It's frigging loud, popping like mad through the 'zorst.
The only thing is, it won't idle it only runs when you keep the revs up. I'm going to make a gasket to go between the manifold and the plastic thermal spacer dealy, as it has symptoms of an air leak. If that doesn't get it, I'll try bigger idle jets.
Tell you what though, it shifts a bit.
Loud and fast.
Jus how i like my weemeen choono.
Sounds beyond awsomostity dude.
Cant wait to hear it barking.
- filthyjohn
I'm surprised you didn't hear it on saturday man, PROPERLY ANTISOCIAL!
Bump start (eventually) FTW. Guess that's why the 340 is ligther than a 60 mate, as they knew it would be getting unreliable twin cam Frenchness shoved in the bay in their later years lol.
Sounds immense I are agree
Get rich or die tryin'!
- filthyjohn
It needs to live by friday, as some sheffield mates are coming up. It would have been done by now if I hadn't spent the last 2 days down in sheff, off my face.
filthyjohn wrote:It needs to live by friday, as some sheffield mates are coming up. It would have been done by now if I hadn't spent the last 2 days down in sheff, off my face.
Fuckin waster
Glad to see yove finally got your priorities straight dude.
Abandon car.
Party.
Return to car.
Succeed.
Two thumbs up.
The valvo just probly needed a little break from you man.
A little ME time.
But for IT.
Abandon car.
Party.
Return to car.
Succeed.
Two thumbs up.
A little ME time.
But for IT.
Is that Airolf?OapEM wrote:filthyjohn wrote:It needs to live by friday, as some sheffield mates are coming up. It would have been done by now if I hadn't spent the last 2 days down in sheff, off my face.
Fuckin wasterStill up for Ford Parts (:O I said a bad word on here) in the morning kiddo?
Starring Stringfellow Hawk.
Airofl maybe dude
*edit I guess that's what you had meant to type? Stringfellow whaaa?
As for his Valvo needing a break - it decided to work before he vactioned off to the glorious south. It just decided to Cliown him for no viable reason.
- filthyjohn
Cliowned or volvowned, that's what all the boyos are gonna get this weekend.
That roflcopter is the best thing I've ever seen.
