360s breaking: mk2 GLS and mk3 GLT
Re: 360s breaking: mk2 GLS and mk3 GLT
Post by 340GLT »
Diferent spline from memory and have bulges in them to stop them winding up....
joeh
Post by joeh »
Alright mate, have you still got front struts -springs&dampers etc complete from 360GLT? Are they in good nick? How much you want for them if you have? Also rear springs from 360GLT? Bonnet and doors? Cheers, Joe
I need the suspension from the GLT, sadly. I potentially know of an earlier set (with 340-style front anti-roll bar), though.
From memory, the GLT's panels aren't great, but I'll check. However, I have a nice clean bonnet from another car.
The cars were in Worksop, up until a week or so ago, but I think they're now in Doncaster. The bonnet is with me in Lincoln.
joeh
Post by joeh »
Shame about the suspension, it's a GLT one that I'm after, uprating my GLE's ....or trying too :)
How much are you wanting for the bonnet?
Where were they in Worksop? Must have missed that seeing that I live here!!!
Cheers, Joe
Post by trabitom99 »
Still up for heater valve, radio and rear seat belt James (all Mk2 - sorted in order of "priority"). PM me at your leisure about postage / payment details etc ;-)
pyro
Post by pyro »
Hi,
dont supose there is any chance or rear leaves from something to fit my 360? somewhere near york ish as ive no long distance car!
driving a series landrover for over an hour makes your ears bleed!!
ben
* Disclaimer
Mors Principium Est
Bazboy
Post by Bazboy »
Hey James,
Is the window trim going to be obtainable and dont worry about the valance ive decided to rebuild mine or at least try, oh also mk2 grill and the other bits i enquired about. Pm me if its easier for you.
Cheers Dan
SteveP wrote:Do GLT driveshafts differ to GLE/GLS ones?
Identical at either end, but the 360 driveshafts have thicker ribs on them I guess to handle the extra power better. I think the split is maybe injection rather than GLT vs others as my GLEi has the thicker driveshafts. The carby ones are identical to the 340.
BTW Foggy, have you got a driver's side front seatbelt, and also a rear left hand side seatbelt, if the saloon isn't different to a hatch.
Post by 340GLT »
@ joeh, i have a pair of GLT springs if your interested, have 1 coil cut off from memory.
Well..not Worksop as such. They were tucked away at a yard near Kiveton Park. I think they've been moved by now, anyway. The bonnet owes me about £25. Does that sound interesting?
Seatbelts should be cool, Andy. Vadis says the rears are the same.
Ben - I'm confused by your reference to springs. The GLS springs won't be an upgrade (I need the GLT ones!)...or have you damaged a spring in some way?
No problem Tom - I'll be in touch.
Dan...side window trim? It's chrome on the 3-door. It tends to be a pig to remove, but I'll see what I can do.
Sorry I'm being typically rubbish about sorting this stuff out guys...but I've been working flat out on getting my S70 back in action. As of this evening, it is...so I'll press on with sorting this stuff out in the next day or two.
Bazboy
Post by Bazboy »
I was looking for the windscreen and boot window screen what ever the big window on the back is called :lol: trims as my side ones are ok but the others are cracked like a crazy.
Cheers Dan
They'd have to come from the GLT to match your car. I'm sure we can sort something out ;)
Not to mention other forums......sheesh, no probs Foggy, I'm in no rush :) Good work on getting the S70 back together. Was it new engine time or did you take the head off?
pyro
Post by pyro »
heyhey
foggyjames wrote:Ben - I'm confused by your reference to springs. The GLS springs won't be an upgrade (I need the GLT ones!)...or have you damaged a spring in some way?
im meant some thing that i could double leaf mine with...
thanks - ben
* Disclaimer
Mors Principium Est
magnumpi
Post by magnumpi »
Whats the rear panel like where the number plate bolts to? Mine's as rotton as a very rotton pair and would like the whole rear section from light to light if you get me and most of the inner boot panel aswell.
That possible?
