+/- 0,16 deg of 0 woud also mean that a to-out of 0,16 is tolerated by factory spec; i'm having a bit of troubles imagining that as it would get a very weird handling
i've had them all between -0,20deg and -0,03deg
i do have to admit that they used the wrong procedure for bending the axle, it shows weak points at the bends; if they would have used a slightly higher grade steel or pre-heated it, it would have been a lot stronger allready.
If you havn't figured out by now I am exceedingly obsessed by rear toe-in, I have never found camber to be an issue.
Toe-in particularly on the left side without the tie bar, can be seen as the wheel is not in the centre of the wheel arch (I think), but peering down from above also shows it more accurately. The different light reflection intensity also seems visible in photo's with steering wheels straight ahead.
As discussed above I think it is the result of reving up for wheel spins with good tyres on a good surface, mainly because it happens fairly equally on 1.4s and 2l.
I also measured the axle recently, it is about 4mm narrower in the curved parts (horizontally), making the curves weak for toe-in forces.
Something strange...I have my rear axle out and stripped down. Measuring the angle of the toe-in with 2x 1.5m box section lengths I seem to be getting an in-spec angle. Its 4mm difference over 1.5m (which equates to <0.08 deg for each wheel).
I am measuring in the straight position of the axle box bits section and assuming it sits flat.
Either;
1. The axle doesn't sit flat normally and I am measuring it in the wrong plane, and it is bend in a different one.
2. The axle rotates for some other reason and the camber starts to make toe-in because of the rotation.
My anti tramp bar/radius arm was very hard to remove, and the bushes where knackered, I wonder is it nothing to do with the axle bending and its just rotation.
If that was the case it would mean the rear radius arm adjustment is very important, especially for lowering.
Will have another crack at it on Friday. Any suggestions on axle 'flatness'/ angle to ground? What is yours, what should it be?
