Anjo's 340Turbo: EFI conversion
Re: Anjo's Project Car: 1986 340GT Special, B14Turbo
Post by volvodspec »
lol, you should be glad i resize the pics before uploading. otherwise loading this page on a random browser would take forever :P
here's todays progress:
took the turbo off
because i forgot..
to drill a hole in it :P
for the EGT sensor
after that, turbo got back on
cut a few bends to a 45degree angle
tacked the first bit of downpipe together
got the car up to working height
exhaustline up to working height
and these are ment to go together eventually :lol:
spot-on!
downpipe all tacked up;
and then the welding:
AFR sensor bung
all done:
3" solid bracket
2,5" bracket for mounting in rubber rings
just for laughs :mrgreen:
http://www.youtube.com/watch?v=0fFhlKecdr4
more tomorrow after work :D
jon-ovlov
Post by jon-ovlov »
I approve of those welds! Fantastic work! Man, wish I could weld. :(
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Frits
Post by Frits »
At least you're off the street :lol:
Goed bezig dude
some work on the shortshifter
had the wrong pair of pliers to get the lockring back in, or it would've been done
and i made a plate to hold the fuelpump and filter
Post by Hell Driver »
The good work continues. I always know we're in for a treat when my computer takes ages to download the page! We have a poor broadband speed here despite being on the edge of a big town.
343 DL (W 80) :-)
R.I.P. 77 343 DL vario :-(
shortshifter = done
http://www.youtube.com/watch?v=A_JNOIbtedk
downpipe,
remaining exhaust + bracket for fuelpump/filter mounted
cut the tailpiece a bit different
and on with the engine..
it's coming together quite well, need to make a few more stainless steel bits and bobs before assembly can continue. nearly there,. well. for now atleast :wink:
Really cool. BTW, why do you have a CAT on the exhaust? Did holland have CATs as standard quite early on?
huh, why do you think that :P ? i doesn't have a CAT and will never get one. the round flange is for a V-band clamp, just like the one behind the turbo. i prefer those clamps over traditional bolted ones or sliding 2 tubes over eachother and clamp them. the tailpiece is with the 2 tubes sliding over eachother, but eventually the exhaust is going to the rear with that huge fartcan welded to it, if i find more time lol.
in holland CAT became stock on 300's from modelyear 88 due to the law but now depending on the code on the vehicle's papers you are allowed to remove it if the car's older than 19xx (i thought 1991 but i'm not sure on that, those rules change every few years...)
Post by trabitom99 »
Great work, as ever ...
I'm stuck with my cat here unfortunately ... A (3-way) cat's really important in Germany for tax and city admission :(
Jtbo has got about 5 cats........ :lol:
Im not a fan of them.
I am a fan of this thread though.
Awesome work as ever dude. 8)
Maybe I should just tie a moggie to my exhaust instead ;-)
Ahhh that makes sence. I've just seen cats that look like that
done a bit more assemblywork..
was very pissed when i found out i forgot to order a hose nipple for the turbo oil feed, now i'm waiting for the Royal Mail to get it here :roll: would've started the car up on wednesdayevening if i had the chance..
and started on what's going to connect to these hoses;
piece of stainless rectangular tube to start with
with a piece of sheetmetal that's an inch shorter than the tube and slot in at an 3D angle, cut to size
welded in place
endcap welded on
and here's the idea..
breatherhose goes into the top chamber, the plate is at such an angle that condensed oil will drip down to the lower chamber; at the back of the tube all goes around the corner to the lower chamber, where at the bottom corner of the lower chamber the oil can run back to the sump, and at the top corner of the lower chamber the sumpvapor wich by now should be free of oil can vent to the open air. there's going to be a filter in the lower chamber to further enhance the separation of oil and air to make it as efficient as possible
i've cleaned the welds with a wire brush, shiny eh :D 8)
finishing this tomorrow, hopefully along with the throttle cable and final bits of coolant hoses. after that it's only a matter of installing the gauges and that dawm oil feed before i can start ripping the bricks out of the road again sm4
oil seperator finished:
pretty much complete under the bonnet now...
