Page 25 of 43
Re: Fake - F7R Motorsport Daily
Posted: 02 Jan 2011 08:13 pm
by Speedy88
haha this kind of thing tends to happen to me also :lol: Bad chi flow and all that.
About to go out, listen for the sound of exploding valver
Posted: 02 Jan 2011 08:55 pm
by sven360
Hmmmmm.......would I be right in thinking a title edit may be called for??????
Unlucky Chris.
I'll watch this with intrest as we had drivetrain issues out back but torque tube was always fine :?
@VND six numbers between 1 and 49 by 19.22 hrs 05/01/2010.Cheers.You is blessed.
Posted: 02 Jan 2011 11:48 pm
Magnum, ouch, sorry dude. Let me know if I can help.
Rupert could well be right re mine getting more abuse than most. I've some pics, prop is fine this time, not found cause yet though. Engine unplumbed and out tomorrow morning if weather not soggy.
Frits, I agree re prop, it's weak. Its the main reason I can't afford to run a slipper yet.
Posted: 03 Jan 2011 12:18 am
by magnumpi
No worries mate, i shouldn't tempt fate, feel like a jinxed myself :lol:
I have a spare prop in the garage so should be ok, just means i'll be on the hunt for another one now as back-up. Mine let go @60mph or so, when going from 4th to 5th. Just felt like i missed the gear and the revs went up with no movement. At 1st i thought it was the clutch but when i looked with the AA dude, you can hear the rubber spinning in the prop.
Posted: 03 Jan 2011 02:39 am
by macplaxton
Hang on to all your dud props for the big souped-up exchange programme that just may well happen one day.
Posted: 03 Jan 2011 08:13 am
by volvosneverdie
Bad luck Magnumpi.
Im getting rather friendly with the AA too. :roll:
Posted: 03 Jan 2011 11:55 am
macplaxton wrote:Hang on to all your dud props for the big souped-up exchange programme that just may well happen one day.
This
Its already secretly underway ;) Dont tell anyone though, they'll only expect me to finish it.
Posted: 03 Jan 2011 07:18 pm
Right then, pictars
More at http://www.flickr.com/photos/c_cardwell ... 320838258/
Looks like nothing else is broked. Prop is fine, as is clutch. Weird.... now I'm dubias. Will take more this apart.
EDIT: It's starting to make sense in my head... will have another beer and post up what I thinks happened...
Posted: 03 Jan 2011 08:09 pm
by volvosneverdie
Chris_C wrote: EDIT: It's starting to make sense in my head... will have another beer and post up what I thinks happened...
Im on a roll, im gonna have a go.
Its broken because a dazed tortoise was wandering along a country lane, having awoken fron hibernation far too early because of global climate change.
Chris drove over it, it pooped its tiny tortoise pants, jumped in the air just as you were passing overhead and it cracked your bell end with its rock hard body-helmet. Then it spun off down the road, got stuck upside down and was devoured by fox. Or a gang of no good stoats.
This explains why nothing else was damaged.
And why my mates tortoise hasnt come home.
Close?
Posted: 03 Jan 2011 08:24 pm
by sven360
Hmm......how hard ya been kickin' the clutch :D
That's gotta be mis-alignment,surely??
How is the tail of the bellhousing held if at all?????
Ali is pretty high so don't bin it.
Drink up and share your thoughts.
Posted: 03 Jan 2011 08:52 pm
by Speedy88
My guess would be that the engine was twisting up on the knackered mounts, but with the near side bellhousing mount not budging. A long period of this caused the alloy to weaken along the line it finally snapped on.
Posted: 03 Jan 2011 09:01 pm
by Frits
Check your engine mount brackets (to subframe) carfully. I've had two broken on my 340.
Edit: Like this:
If i'm right, you have one alloy, wich is even weaker.
Posted: 03 Jan 2011 09:12 pm
Frits, I had those off when I dropped the subframe over summer, but... I dont remember giving them a super hard look over so will do that now, thanks.
My thoughts...
I havn't had the pressure plate off of the flywheel yet, but it looks
ok in there. It looks to me as though stress on the clutch arm has
caused this somehow though not sure quite how. Thinking back, I've
been thinking the clutch has been high for a while and that I need to
adjust it, but a quick think in my head makes me think this is
opposite to the symptom of that crack being there.
For reference, on this pic
My left hand is at 1oClock, right hand at 10oClock, from crack at 12oClock
12 - Crack
12:30 - Hole that clutch cable outer stops in, activation arm behind
1 - Left Hand, obscuring tiny bolt that holds cover/inspection plate
onto bellhousing, doesnt hold bellhousing onto block
3 - Other tiny bolt as 1oClock
4:30 - Bolt onto block
5:30 - Bolt onto block, then 2 of the 3 starter bolts can be seen
7 - Bell housing to block bolt
7:30 - Crank position sensor bolt1
8:30 - Crank pos bolt2, bell housing to block bolt
9:30 - Bell housing to block bolt
11:30 - Bell housing to block bolt
So... Only 2 of those critical bolts, rather than other things bolts
(4:30 and 5:30) hold the entire thing onto the block, soooo. I think
that 6 till 12 are holding onto the block, and the actual useful bit
has been hinging about the crack point which is what caused my prop to
go too.
So, next question... apart from possible tortoises (which is currently the only thought of theory that makes sense) why did it crack? I reckon I may have hit VTack :lol:
Posted: 03 Jan 2011 09:15 pm
by macplaxton
volvosneverdie wrote:Im on a roll, im gonna have a go....
"It's good, but it's not right" :lol: :lol: :lol:
Posted: 03 Jan 2011 09:47 pm
by zombeh
I reckon somebody told it you were going to put it on a track and it didn't like the sound of that.
I meant to ask earlier, how far round does the crack go? it looks like it's heading for the starter that clearly doesn't fit but I can't tell how close it gets to being in two pieces.
