Evoman's 360 GLT
Evoman
Re: Evoman's 360 GLT [More Lots of pictures! p25]
Post by Evoman »
ah! might have solved it then. I was looking for something more serious :P
mat_91
Post by mat_91 »
yer there pretty beefy just try it and find out if they work for you
Evoman
Post by Evoman »
Re: Evoman's 360 GLT [New Wheels]
Post by MCHUDD »
Hi Evoman.
Those wheels look great
Car looks great as always.
sm4 sm4 sm4
Evoman
Post by Evoman »
Cheers Mark :)
Some much better photos
mattywatsit
Post by mattywatsit »
Evoman wrote:Cheers Mark :)
Looking very smart! Are they the ones I spotted on eBay for you? :)
Look bettee on your red GLT than they did on my silver one actually! Really set the. car off.
Matt
Those look AWEsomes man.
A million times more aggressive than the previous.
Evoman
Post by Evoman »
Cheers VND :)
Three more photos
One iusse though. The offside rubs on the spring cup, but the nearside doesn't :? same tyres!
Nimminz
Post by Nimminz »
very nice! those wheels do really suit the car, especially as yours is red!
Evoman
Post by Evoman »
Couple of photos
I seem to have coolant leak, I am pretty sure my Head gaskets is the cause. I can see coolant leak down the block on the forward most cylinder, it does appear to be from the water pump (its only 3000 miles old) and theres no coolant pipe close.
So head gasket has been ordered and its alittle job to fit in between uni work for next week :?
It must be head gasket month dude. Theyre all at it.
Car looks cracking as ever though. Megacools. 8)
Nimminz
Post by Nimminz »
car does look good mate! hope the headgasket goes ok!
Evoman
Post by Evoman »
Im doing the headgasket tommrow. Any tips or advice? things to watch for?
I'd make sure you undo the head bolts in the correct order, not sure with the redblock ones but check if you need to replace the bolts (some cars you do), check the head is completely flat using a flat edge, if not it could need skimming. Follow pettaw's youtube video and you'll be fine :)
V6 Man
Post by V6 Man »
It might be the waterpump to head seal that's gone, not the headgasket. The pump has a rubber O ring that is on top of the pump and under the overhang of the head. If the ring has perished, been squashed or fitted incorrectly it'll leak coolant down the foremost cyl side of the block.
