Page 28 of 35
Re: Evoman's 360 GLT [More Lots of pictures! p25]
Posted: 04 Jan 2012 10:39 pm
by Evoman
ah! might have solved it then. I was looking for something more serious :P
Posted: 04 Jan 2012 10:55 pm
by mat_91
yer there pretty beefy just try it and find out if they work for you
Posted: 22 Jan 2012 06:06 pm
by Evoman
Re: Evoman's 360 GLT [New Wheels]
Posted: 22 Jan 2012 08:39 pm
by MCHUDD
Hi Evoman.
Those wheels look great
Car looks great as always.
sm4 sm4 sm4
Posted: 22 Jan 2012 09:03 pm
by Evoman
Cheers Mark :)
Some much better photos
Posted: 22 Jan 2012 09:10 pm
by mattywatsit
Evoman wrote:Cheers Mark :)
Looking very smart! Are they the ones I spotted on eBay for you? :)
Look bettee on your red GLT than they did on my silver one actually! Really set the. car off.
Matt
Posted: 22 Jan 2012 09:40 pm
by volvosneverdie
Those look AWEsomes man.
A million times more aggressive than the previous.
Posted: 22 Jan 2012 09:48 pm
by Evoman
Cheers VND :)
Three more photos
One iusse though. The offside rubs on the spring cup, but the nearside doesn't :? same tyres!
Posted: 22 Jan 2012 11:20 pm
by Nimminz
very nice! those wheels do really suit the car, especially as yours is red!
Posted: 03 Apr 2012 07:03 pm
by Evoman
Couple of photos
I seem to have coolant leak, I am pretty sure my Head gaskets is the cause. I can see coolant leak down the block on the forward most cylinder, it does appear to be from the water pump (its only 3000 miles old) and theres no coolant pipe close.
So head gasket has been ordered and its alittle job to fit in between uni work for next week :?
Posted: 03 Apr 2012 08:34 pm
by volvosneverdie
It must be head gasket month dude. Theyre all at it.
Car looks cracking as ever though. Megacools. 8)
Posted: 07 Apr 2012 08:49 pm
by Nimminz
car does look good mate! hope the headgasket goes ok!
Posted: 15 Apr 2012 01:33 pm
by Evoman
Im doing the headgasket tommrow. Any tips or advice? things to watch for?
Posted: 15 Apr 2012 01:41 pm
I'd make sure you undo the head bolts in the correct order, not sure with the redblock ones but check if you need to replace the bolts (some cars you do), check the head is completely flat using a flat edge, if not it could need skimming. Follow pettaw's youtube video and you'll be fine :)
Posted: 15 Apr 2012 01:57 pm
by V6 Man
It might be the waterpump to head seal that's gone, not the headgasket. The pump has a rubber O ring that is on top of the pump and under the overhang of the head. If the ring has perished, been squashed or fitted incorrectly it'll leak coolant down the foremost cyl side of the block.
