Duchess The Volvo 340 CVT
Re: Duchess The Volvo 340 CVT
That is a chunk of progress, rear strut towers in the shell look pretty good too, that's a favourite place to rust if the sill drain holes have been blocked
benji1985
Post by benji1985 »
Chris_C wrote:That is a chunk of progress, rear strut towers in the shell look pretty good too, that's a favourite place to rust if the sill drain holes have been blocked
Thank you, I didn't know that was a place to rust, I'll check over with a fine tooth comb
Ben
benji1985
Post by benji1985 »
Good evening.
17/03/16. Today saw most of the remaining parts cleaned up.
Started with the plates that join the rear shock to the leaf springs (not sure what they are called).
Before
ImageIMAG3930 by Benjamin Charlton, on Flickr
After
ImageIMAG3931 by Benjamin Charlton, on Flickr
The next items that came to hand were the front suspension strut top spring cups, it was mentioned that these can crack, so cleaned as much rubbish off as possible, to find no cracks at all :D :340: sm4
Before
ImageIMAG3932 by Benjamin Charlton, on Flickr
After
ImageIMAG3933 by Benjamin Charlton, on Flickr
I then decided to work on the other front suspension strut, this one cleaned up nice and also the spring cups are in good condition, and also managed to drill out the broken bolts, the first broken bolt drilled out in minutes, the second however broke 4 drill bits and damaged many more, thankfully with help from the father in law and a pillar drill it came out, I was going to tap these holes and as much as I think the first hole would tap nice I fear the second one might break a tap, so just going to bolt through with a nut on the end.
ImageIMAG3934 by Benjamin Charlton, on Flickr
ImageIMAG3935 by Benjamin Charlton, on Flickr
The next parts were the calipers, I had been putting them off but cracked on with them.
They did clean up well too, but will need a rebuild kits and I am not sure if the pistons need replaced?
ImageIMAG3936 by Benjamin Charlton, on Flickr
ImageIMAG3938 by Benjamin Charlton, on Flickr
ImageIMAG3937 by Benjamin Charlton, on Flickr
The rear lights have been finished off, all new wires added for earthing issues.
ImageIMAG3943 by Benjamin Charlton, on Flickr
ImageIMAG3944 by Benjamin Charlton, on Flickr
ImageIMAG3945 by Benjamin Charlton, on Flickr
Also new parts arrived and with thanks to Tom who gave me some new wheel nuts, the longer wheel studs have arrived :D
ImageIMAG3941 by Benjamin Charlton, on Flickr
This is all for now, back to work again, more to happen on Tuesday :D
Ben
viewtopic.php?f=52&t=5953&start=315#p125303
Start with the photo above that link for what it looked like before it was poked, then the amount that had to be chopped out ;)
Something calming about seeing someone using brown wire for the rear cluster earth mod! Nice one
benji1985
Post by benji1985 »
Chris_C wrote:viewtopic.php?f=52&t=5953&start=315#p125303
I am so glad mine is not that bad! But only time will tell.
Ben
benji1985
Post by benji1985 »
Hello all, well the progess has gound to a halt, mainly due to the wet weather...
But, my new bolts turned up to join the manifolds together, these are titanium aerospace quality bolts.... yes i had to get that in there, sadly they wont be seen :roll:
The bolts were 1 x M7x1x40 and 2 x M7x1x50 and as you can see they are not much different to the originals.
ImageIMAG3952 by Benjamin Charlton, on Flickr
ImageIMAG3953 by Benjamin Charlton, on Flickr
Also my caliper re-build kits have arrived :D
A big thank you to Mac for helping on the bolts and the re-build kits and also Tom for help with the bolts too sm4
While i had a bit of sun for good friday, i decided to get the calipers and drums painted up
I cant say i am completely happy with the VHT paint, it is a nice colour but does spray a little strange (might very well be me and my lack of skills)
ImageIMAG3961 by Benjamin Charlton, on Flickr
ImageIMAG3960 by Benjamin Charlton, on Flickr
Anyhow this is all that has been achieved on Duchess, also did the front discs and pads on the mother-in-law's 307cc.
Heres hoping that the weather will improve so more work can go ahead
Watch this space for more updates :D
Ben
Post by bogbasic »
Epic work, space it out, man.
benji1985
Post by benji1985 »
bogbasic wrote:Epic work, space it out, man.
I am trying to space it out, but once I start something I like to get it done. I know no patience lol
Ben
benji1985
Post by benji1985 »
Hello all, today i decided to try and get a few things sorted towards the car.
30/03/16
Today i received my package from Mac, my carb has been completely re-built, here's the story pictures courtesy of Mac.
Mac received my carb plus a second carb that i had that was no use to me,
Imageimage-3_zpsmx2kxdmf by Benjamin Charlton, on Flickr
mine was dismantled
Imagephoto 1-1_zps7tw5dpgr by Benjamin Charlton, on Flickr
then it was cleaned
Imagephoto 3_zpsceigp8fy by Benjamin Charlton, on Flickr
the holes for the studs were helicoiled
Imageimage-1_zpsnajl0yu6 by Benjamin Charlton, on Flickr
All the other parts were ultrasonic cleaned
all these parts look amazing
Imagephoto 2-1_zpsn430itxb by Benjamin Charlton, on Flickr
Imagephoto 4_zpsjai1xevb by Benjamin Charlton, on Flickr
Carb ready to go back together
Imagephoto_zpsr84yojco by Benjamin Charlton, on Flickr
Then all put back together, I have to say i hardly recognize that this was once my dirty carb
Imagephoto 1_zps8iblm4y0 by Benjamin Charlton, on Flickr
Imagephoto 2_zpsa4ylwfev by Benjamin Charlton, on Flickr
sm4 :shock: sm4 :340:
Mac has also supplied some re-built drop links which look amazing too
Imageimage-5_zpsqzsilrxh by Benjamin Charlton, on Flickr
I decided to rebuild my calipers, both have new rebuild kits but re-used the pistons and i think the blue calipers and silver caliper carriers are a good contrast
ImageIMAG3962 by Benjamin Charlton, on Flickr
Also decided to change the part on the steering rack to make the rack work with the 340 instead of the 360, thank you Tom for the part.
ImageIMAG3963 by Benjamin Charlton, on Flickr
Again with help from Mac and his hub bearing tool, the outer race were removed :D
ImageIMAG3964 by Benjamin Charlton, on Flickr
Thank you Mac for all your help so far and thank you Tom for the steering rack part.
benji1985
Post by benji1985 »
Good evening all, so more work done today.
31/03/16
today all the cleaned up parts have had the first coat of paint - picture to follow once they are done.
While the parts were drying the rear axle got a POR15 topcoat and some more dismantling happened
first the bumper came off
ImageIMAG3967 by Benjamin Charlton, on Flickr
then the headlight came out ready to be dismantled and clean
ImageIMAG3966 by Benjamin Charlton, on Flickr
ImageIMAG3970 by Benjamin Charlton, on Flickr
also removed the alternator
I attempted to remove the exhaust, knowing that the back box was holed and the downpipe was very rusty sadly the exhaust would not separate, so it .....erm...... bit the dust, managed to get the downpipe saved
ImageIMAG3968 by Benjamin Charlton, on Flickr
the prop shaft was removed
ImageIMAG3986 by Benjamin Charlton, on Flickr
ImageIMAG3969 by Benjamin Charlton, on Flickr
I removed fuel tank
ImageIMAG3987 by Benjamin Charlton, on Flickr
ImageIMAG3988 by Benjamin Charlton, on Flickr
Then the CVT units came out and separated
ImageIMAG3971 by Benjamin Charlton, on Flickr
The CVT mount was dismantled as the rubber mounts would not come undone
ImageIMAG3972 by Benjamin Charlton, on Flickr
ImageIMAG3982 by Benjamin Charlton, on Flickr
ImageIMAG3983 by Benjamin Charlton, on Flickr
Now the CVT unit, the fuel tank, prop shaft and exhaust are out, good chance to look over the underside, over all she looks good, there is a little bit of surface rust, the chassis looks really clean and good.
ImageIMAG3974 by Benjamin Charlton, on Flickr
ImageIMAG3975 by Benjamin Charlton, on Flickr
ImageIMAG3976 by Benjamin Charlton, on Flickr
ImageIMAG3978 by Benjamin Charlton, on Flickr
ImageIMAG3979 by Benjamin Charlton, on Flickr
ImageIMAG3980 by Benjamin Charlton, on Flickr
So se shall see what tomorrow bring :340: sm4
benji1985
Post by benji1985 »
Hello all the next days installment
01/04/16
Today I painted the other side of the parts and top coated the suspension struts, the rear axle is now finished.
ImageIMAG3989 by Benjamin Charlton, on Flickr
Front suspension struts
ImageIMAG3994 by Benjamin Charlton, on Flickr
ImageIMAG3995 by Benjamin Charlton, on Flickr
ImageIMAG3996 by Benjamin Charlton, on Flickr
ImageIMAG3997 by Benjamin Charlton, on Flickr
ARB links
ImageIMAG3991 by Benjamin Charlton, on Flickr
Torque rods
ImageIMAG3990 by Benjamin Charlton, on Flickr
Brake drum back plates and handbrake leavers
ImageIMAG3992 by Benjamin Charlton, on Flickr
Torque rod (i think)
ImageIMAG3993 by Benjamin Charlton, on Flickr
Lower suspension arms, front suspension top mounts, rear suspension shocks to leaf springs and engine beam mounts
ImageIMAG3998 by Benjamin Charlton, on Flickr
So this is it for a little while till the weather clears up a bit, but the next job is the re assembly of the rear axle and cylinder head also have some more parts to get cleaned up, this will happen while it rains lol
Enjoy and watch for more updates :D
Ben
benji1985
Post by benji1985 »
02/04/16
As the weather was nice today I decided to make a start on the cylinder head.
The end plate came off quite easy
ImageIMAG4000 by Benjamin Charlton, on Flickr
next the rockers and valve came out
ImageIMAG4006 by Benjamin Charlton, on Flickr
all the manifold stud were removed
ImageIMAG4007 by Benjamin Charlton, on Flickr
next was the studs that hold the rockers and cover
ImageIMAG4008 by Benjamin Charlton, on Flickr
Then i had a basic clean up, removed the remaining gasket material.
cleaned up quite nice.
ImageIMAG4009 by Benjamin Charlton, on Flickr
ImageIMAG4010 by Benjamin Charlton, on Flickr
ImageIMAG4011 by Benjamin Charlton, on Flickr
All ready for a good clean now :D
ImageIMAG4012 by Benjamin Charlton, on Flickr
more to come next week
Ben :)
thododd
Post by thododd »
Is that the spare head?
benji1985
Post by benji1985 »
thododd wrote:Is that the spare head?
It is indeed, cleaned up nice?
Post by MCHUDD »
That is some work your putting in there. Brilliant.
